71 coupe question
Old Jan 6, 2009 | 08:23 PM
Daffy's Avatar
Daffy
Florida turtle advocate
St. Jude Donor '05-'06
Default 71 coupe question
I won't get my car till tomorrow but I noticed it had a lock cylinder in the back like a trunk lock...My 68 didn't have this..What is it???
Old Jan 6, 2009 | 08:29 PM
joewill's Avatar
joewill
factory alarm.... you should see a horn behind your left rear tire just above the side marker light..
Old Jan 6, 2009 | 09:26 PM
Daffy's Avatar
Daffy
OK Thanks...Tomorrow I'll be on here with all kinds of questions...This is only my second C3 and my first 70-72 so it's a new deal for me...
Old Jan 7, 2009 | 10:39 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
When you get the car, you will want to make sure the alarm key is included. They do not work off the ignition/door keys.
Old Jan 7, 2009 | 11:20 AM
early shark's Avatar
early shark
Daffy,
That factory alarm system uses a pin switch with three locations. One for each door, and one for the hood. This is what activates the horn honking when either door or hood is opened with the alarm switch turned on that is in the rear panel.
Old Jan 7, 2009 | 12:22 PM
gq82's Avatar
gq82
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
In 71 the alarm key is the oval key which also operates the inside center storage lock and spare tire lock.
Old Jan 7, 2009 | 02:02 PM
Bruthish's Avatar
Bruthish
St. Jude Donor '03-'04-'06-'08-'09
if you have it. Mine didn't come with one
To 71 coupe question
