385,400,427 ???
Old Jan 19, 2009 | 10:51 PM
68vetteman's Avatar
68vetteman
Default 385,400,427 ???
It's snowing so I am thinking about a better engine for my car. I have a 350 block to be bored and stroked for a 385. I can also get a 400 block from the machine shop. Both of these would work fine. Is it possible to stroke the 400 block with a 4" throw on the crank to make it a 427" small block and have the crank clear the cam with 6" connecting rods? I will do the assembly myself. This would be a "cruiser motor" with the occasional open road blast now and then. Any comments or info on the three engines will be helpful.
Thanks,Dave
Old Jan 19, 2009 | 11:21 PM
Ed Campbell's Avatar
Ed Campbell
Whatever you do I suggest you upgrade the cooling system. Ed
Old Jan 20, 2009 | 12:00 AM
aussiejohn's Avatar
aussiejohn
Default 427???
vetteman,
You won't get 427 cubic inches with a 4.00" stroke and the standard 4.00" bore. That will only give you 402 ci. You will need to bore out to about 4.125" to get to seven litres. You can obtain 7 litres with a 4 inch bore, but would have to stroke it to 4.25" and then the rods would be getting pretty friendly with the camshaft.
Not saying it can't be done, but it would take $$$$$$$$$$$$$$$$$. If only Chevrolet had put the camshaft passage in the block about half an inch higher up and the side rails about half an inch further apart. I guess we'd never have had the big block if they'd done that.
Regards from Down Under
aussiejohn
7 months to go
Old Jan 20, 2009 | 01:58 AM
gkull's Avatar
gkull
people do make 4 inch stroker 350's and 400 blocks. I prefer the 3.875 cranks.
I do not like or build stock 400 blocks.
www.flatlanderracing.com is where I buy the complete rotating kits
Old Jan 20, 2009 | 08:44 PM
68vetteman's Avatar
68vetteman
Originally Posted by aussiejohn
vetteman,
aussiejohn
7 months to go
Thanks for the reply aussiejohn.
The 400 blocks have a 4.125" bore from Chevrolet as the standard size. Unfortunately they also have a cracking problem on the decks where the "steam holes" are. Hope it's warm where you are. Cold weather sucks.
68 Vetteman
Old Jan 20, 2009 | 08:52 PM
68vetteman's Avatar
68vetteman
Thanks for the website gkull.
They have some interesting stroker crate engines.The shop that has the 400 block told me they have a problem with cracks on the decks near the head bolts.
68 Vetteman
Old Jan 20, 2009 | 09:29 PM
MotorHead's Avatar
MotorHead
From: Who says "Nothing is impossible" ? I've been doing nothing for years.
Best bang for your buck is a 406ci,400ci block and 3.75" stroke crank, no clearancing necessary and big cubes and big power. Check into it, get the block from the machine shop doing the work, then it's their responsibility
I built a 427ci but used aftermarket Motown block and 4 inch crank, very happy with the results
Old Jan 20, 2009 | 11:05 PM
68vetteman's Avatar
68vetteman
Thanks MotorHead
The stroked 400 block sounds tempting. Great looking 427. How close does the crank come to the cam with a 4" stroke? Did you have to use a small lobe cam on your 427?
Thanks, 68 Vetteman
To 385,400,427 ???
