69 and 76 difference
Old Jan 25, 2009 | 02:07 PM
mpro71vette's Avatar
mpro71vette
Default 69 and 76 difference
Hi All,
Is there any difference between a 1969 and 1976 birdcage? How about the frame?
Thanks!!
Old Jan 25, 2009 | 02:45 PM
champs65's Avatar
champs65
Frame is different, front and back at the bumper mounts at the end of the rails. There is a site detailing all the 63-82 frame changes; I'll see if I can dig it up.
Also, I think the later frames all had removeable transmission crossmembers. Someone with a definitive answer I'm sure can chime in.
I would guess the birdcages are the same, unless there was some kind of variation over the years where the seatbelts mounted.
Old Jan 26, 2009 | 10:38 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Birdcages will be pretty close with the exception of a '69 convertible cage.
Old Jan 26, 2009 | 01:57 PM
C3 4ME's Avatar
C3 4ME
later cars did not have a removeable crossmember if it was a 4 spd.
Old Jan 26, 2009 | 07:30 PM
mpro71vette
Thanks guys!
Old Jan 28, 2009 | 12:38 PM
71coupe454's Avatar
71coupe454
how can you find out what frame you have in a car? mine was changed to a 4-speed frame but I have no idea what year it is or what any differences might be?
Old Jan 28, 2009 | 05:30 PM
Easy Mike's Avatar
Easy Mike
Check to see if the A.O. Smith factory stenciled part number and date are still legible. 81 shown.
Earlier cars had the stencil on the passenger's side rail.
Old Jan 29, 2009 | 10:18 AM
71coupe454's Avatar
71coupe454
no luck on any stencil still being there, the 4-speed frame was sand blasted and painted by the shop the previous owner had working on it. I have noticed a couple bolt holes that are missing or dont line up with the parts on the body that bolt to it.
Old Jan 29, 2009 | 01:45 PM
vette54728702's Avatar
vette54728702
If I'm not mistaken, I believe the 76+ birdcage has metal floor pans... previous to that they were fiberglass.
To 69 and 76 difference
