Hooker sidepipe headers
Old Jan 25, 2009 | 09:07 PM
bobl.2's Avatar
bobl.2
Default Hooker sidepipe headers
As you know I have a 77, this has the third set of tubes in 6 years. The tubes rot out on the top of the tube, about 8 inches from the collector. The car is in WI, but the car does no see rain or snow. What is up with the rot on the top of the tube? P.S. the car is not in a climate controled garage, however it remains about 40 degrees at the coldest times of the year. Any ideas here?
Old Jan 25, 2009 | 09:11 PM
Durango_Boy's Avatar
Durango_Boy
Happens to me too, and I"m in Missouri. Maybe it's a '77 thing?
I have always attributed it to the humidity and condensation in my cave of a garage, and moisture that rots it from the inside too.
Old Jan 25, 2009 | 09:19 PM
dannyman's Avatar
dannyman
Mostly short trips? Temperatures, as well as airflow; are not consistent throughout the tubes during operation.
Old Jan 25, 2009 | 10:33 PM
bobl.2's Avatar
bobl.2
Default Hooker headers (tubes)
I guess I am somewhat relieved that this has happened to someone othe than me. No not just short trips. When I drive the car during the spring, summer, fall months, The shortest trip is well over 30 miles. The car has never seen or been exposed to salt, or wet roads in over 25 years (this I know for sure) This is the third set of tubes that I had to buy. Hooker, seems to think that this is a problem they would rather not address, for they have never replyed to this issue either via e-mail or otherwise. I truly love the look and sound of this setup, and don't want to keep forkin out 700.00 eery 2 years to preserve the look and sound of my car. If I am or have done something wrong in the installation or care of these items PLEASE let me know.
Old Jan 25, 2009 | 10:38 PM
Durango_Boy
The best defense is to never let the engine run without it getting to full operating temperature, and keep the collectors as clean as possible. This means maybe vacuuming out the crease of any debris where moisture can be held in. See here when the weather gets humid everything in my garage gets 'wet' and stays moist for a few months. This is horrible on my engines and tools and spare parts. The ones on the car are no exception.
The moisture gets on those collectors and starts to eat at it over time because those creases are a great place to hold moisture. I've never seen a set that didn't have those issues and that includes Jet Hot coated pipes.
Old Jan 25, 2009 | 10:52 PM
bobl.2's Avatar
bobl.2
Default Hooker sidepie headers
DB, Here in WI we do not share the same climate woos as you do. The headers themselves are as good as new, however the recurring problem is the rot ON TOP of the side pipe tube. I could understand it if it were on the bottom side of the tube, but being on the top? and every 2 years for the last six? I am truly baffled
Old Jan 25, 2009 | 11:20 PM
Durango_Boy
Do you polish and wax the pipes? Curt does that to his here in Missouri and they look a lot nicer than mine ever did when I performed minimal maintenance on them. I think his get serviced a few times a year.
Old Jan 26, 2009 | 12:43 AM
curtis74's Avatar
curtis74
It's very important for you to wipe them down after each trip and when finished apply some chrome polish. This will keep them in good shape and reduce pitting. Sounds like you might be having some blow bye at the collector. I had some black exhaust dust blowing up on the top of mine for awhile until I tightened them up.
Old Jan 26, 2009 | 07:44 AM
guitarcrazy02's Avatar
guitarcrazy02
Have you considered the stainless steel sidepipes? I have those on my 81 and, like DB, when the temperatures start to climb just about freezing, everything in my garage starts to sweat. No rusting on my sidepipes, though.
Old Jan 26, 2009 | 09:42 AM
Bangkok Dean's Avatar
Bangkok Dean
I have stainless steel everything and when it gets down to 70* I wipe them down to get the water spots off.
Old Jan 28, 2009 | 10:50 AM
bobl.2's Avatar
bobl.2
I think the stainless idea is the winner. Who would you suggest for info regarding these.
Old Jan 28, 2009 | 11:38 AM
Bangkok Dean
I bought mine from Summit racing, with steel shields to protect friends and family from burning there legs.
Old Jan 28, 2009 | 03:55 PM
guitarcrazy02
Summit Racing got me all my goodies
Old Jan 29, 2009 | 02:38 AM
avner's Avatar
avner
Hi
Did you check the humidity level in the garage?
I checked the humidity in my garage and in the summer it go up to 85% - 90%,
so I bought a humidity dryer (250W) that keep the humidity at 40%-55%.
Avner
Old Jan 29, 2009 | 03:55 AM
g mindenhall's Avatar
g mindenhall
7th Gear
Default hooker headers
it happens to 1979 vettes also when i bought the car it had a cheap set of black painted headers which didnt last very long at all
i replaced them with hooker ceramic headers they are pretty dam good theyve been on the car for about two years the only damage or wear on them is from speed bumps
Old Jan 29, 2009 | 02:41 PM
dariopop's Avatar
dariopop
BOBL.2
What kind of inserts are you running? I also have the Hooker Header sidepipes with STS baffles. I do not have any rust issues. I was just thinking ,with the design of the spiral baffles there is not any area around the baffle to hold moisture because its like an ice auger design ,but if you are running glass packs that are a slip fit there would be areas around the insert that would hold moisture against the tube on the top or bottom of the header. The fiberglass itself can hold moisture .
Dario
To Hooker sidepipe headers
