Door handle help
Old Jan 26, 2009 | 01:36 PM
danimal96's Avatar
danimal96
Cruising
Default Door handle help
The driver side door outside handle quit working. I removed the inner door panel and can see that the rod is not moving. Is there a clip that holds the upper end of the rod to the handle, and if there is, how do I install it.
Old Jan 26, 2009 | 02:47 PM
1stC3Vette's Avatar
1stC3Vette
I believe the rod connects to the handle by inserting through the opening in the linkage. If it is not moving, I would bet that the door handle itself is broken. The bottom of the rod connects to the door latch and is held in place with a clip. If you have an Assembly Instruction Manual, you can see how everything hooks together.
I replaced both of my door handles last year and it was a bit interesting. Search some threads regarding "door handles" and you will see some common issues that occur.
Good luck,
Dino
Old Jan 26, 2009 | 04:39 PM
danimal96's Avatar
danimal96
Cruising
I can see the bottom of the handle move, and the rod slips thru the hole. Is one of the bends in the rod supposed to catch on the door handle?
Old Jan 26, 2009 | 05:36 PM
GD70's Avatar
GD70
Here's 2 diagrams from one of the catalogs. Same as in the AIM. I circled the rod red so you can see where it attaches. Hope this helps.
I fixed my drivers side outside door handle last summer. The rod disconnected and the spring on the outside handle broke. I got some of those springs from the "HELP" rack and made a new one, cleaned up the door lock mechanism and now works smooth as silk.
It's just very tight in there. My 14 year old son was a big help reaching in there.
If the clip fell off, feel around in the bottom of the door.
Glenn
Old Jan 26, 2009 | 07:38 PM
GTR1999's Avatar
GTR1999
There is a clip that attaches the handle to the rod, the adjustment for the throw is in the threaded nut. The best way I found to do them, is to remove the door latche rech up and get the 2 nuts off the handle with the pivot pin out of the latch remove the handle. install a new clip, vendors sell them, clean and lube the latch and install. adjust with the door open until you're sure it's correct then close the door.
Old Jan 26, 2009 | 08:18 PM
danimal96's Avatar
danimal96
Cruising
Thanks guys. I'll pull it into the heated shop this weekend and give it a try.
To Door handle help
