C3 outside door handle replacing
Old Jan 29, 2009 | 03:34 AM
g mindenhall's Avatar
g mindenhall
7th Gear
Default C3 outside door handle replacing
1979 vette door handle
has any one had to replace one i have a new one. im not sure but it looks like i may have to remove the whole door lock assembly in order t
attach the little rod that gos to the handle is there an easier way to do this ?
Old Jan 29, 2009 | 03:52 AM
speedreed8's Avatar
speedreed8
inside handle or outside one.??
http://forums.corvetteforum.com/c3-g...ndle-help.html
Old Jan 29, 2009 | 11:30 AM
c69vete's Avatar
c69vete
Finalist 2021 C3 of the Year - Modified
2017 C3 of Year Finalist
Cruise-In VIII Veteran
St. Jude Donor '07
I just did this on mine. It is a lot easier to remove the door latch assembly when replacing the outside handle. there are 3 bolts holding the latch on and there is no adjustment when putting it back. All of the adjustment is in the rod ends. Just make sure you try closing, opening and lock/unlocking the door before you replace the door panel. If you need to make some fine adjustments, at least you can get to the latch mechanism with the panel off.
Old Jan 29, 2009 | 11:39 AM
g mindenhall
7th Gear
Default out side handle
out side handle
Originally Posted by speedreed8
Old Jan 29, 2009 | 11:40 AM
g mindenhall
7th Gear
outside handle
Old Jan 29, 2009 | 11:53 AM
g mindenhall
7th Gear
i kind of thought i would have to remove the door latch in order to hook up the handle rod thanks
Old Jan 29, 2009 | 04:59 PM
c69vete's Avatar
c69vete
St. Jude Donor '07
You don't HAVE to remove the latch, it just makes getting the to the nuts for the latch a lot esasier to remove and replace.
Old Jan 30, 2009 | 03:36 AM
Solid LT1's Avatar
Solid LT1
I think YOU DO HAVE TO REMOVE the latch if your hands are as big as mine are. Otherwise jobs is tedoius and frustrating, much easier and FASTER if you remove the latch (then you can take some time and clean it up and use some Motorcycle Molly chain lube on it to make it work like a champ when your done.) One other tip, find some new clips for the rod from the door handle to the latch and the rods just push right on into the clip when everything is going back together. I was originally told that you had to slide the clip into position with the rod in the hole of the latch by a guy who dosen't know as much as he thinks he does about Vettes. Also NEVER spray lube on any Vette lock/window components while they are in place in the door as they fiberglass will absorb the oversprayed lube and fail! and possbily cause paint failure too!
Old Aug 6, 2019 | 09:49 PM
Corvette 75's Avatar
Corvette 75
1st Gear
I found replacing the outside door handles pretty easy after I got the latch meconium off
To C3 outside door handle replacing
