Differences in steering columns
Old Feb 1, 2009 | 04:39 PM
kaiserbud's Avatar
kaiserbud
Default Differences in steering columns
I am trying to get a replacement standard steering column for a 73 Vette. I don't want it to be rigged, as I will be re-selling it. Can anyone advise if indeed the 73 column was different... will anything from 68-77++++ fit? thanks
Old Feb 2, 2009 | 04:40 PM
markdtn's Avatar
markdtn
69-76 standard columns should all interchange. '77 up has a different length and has a different style stalk for the turn signals.
Old Feb 2, 2009 | 10:06 PM
kaiserbud's Avatar
kaiserbud
thanks yeah and 77 had an entirely different column with the box around the blinker, cruise, etc. right?
Old Feb 2, 2009 | 10:26 PM
400hp427vette's Avatar
400hp427vette
St. Jude Donor '09
I am not sure how much is not the same but my 69 uses key coded E & H, The 77 I had used codes C & D the grooves on each key were oppisite each other. Also on the 69 the ingnition key works in the doors where as the 77 the square key worked the ignition and the round worked the doors. I'm not sure when what year the change was made.
Old Feb 3, 2009 | 08:46 AM
Jim Shea's Avatar
Jim Shea
Any standard column 1969 through 1976 will bolt right in. You may want to remove the lock cylinder from your original 1973 column and swap it into your new column if you want to keep the keys for you ignition and doors the same.
BTW it was the 1974 model year and later where the ignition key was different from the door key.
All GM cars 1967-73 had square keys for the ignition and doors. Round keys for glove, trunk, and console.
Jim
Old Feb 4, 2009 | 09:01 PM
kaiserbud's Avatar
kaiserbud
thank you
Old Feb 4, 2009 | 11:24 PM
Solid LT1's Avatar
Solid LT1
I think all 76 year Vettes had the so called "Vega" plastic steering wheel so unless you want to buy a new hub to be able to bolt your steering wheel on the replacement column, stop your search at 1975.
Old Feb 5, 2009 | 01:02 AM
kaiserbud's Avatar
kaiserbud
I agree..
I should have mentioned just the column itself, but good point
To Differences in steering columns
