help with sandblasting media
Old Feb 4, 2009 | 12:24 PM
hicswa's Avatar
hicswa
Default help with sandblasting media
So I put together a small sand blast cabinet and got one of those low cfm siphon guns (5 at 90 PSI) with a 3/16 tip. What would be a good media type and grit for removing paint and rust? Also, is black beauty media only used for external bucket type sandblasters?
Danny
Old Feb 4, 2009 | 12:32 PM
eastltd's Avatar
eastltd
Danny
I use Black Beauty in my cabinet and it works well. I've also used crushed glass with good results but it breaks down quicker.
Old Feb 4, 2009 | 01:03 PM
Duke94's Avatar
Duke94
I use the glass beads which will remove all but the really bad rust. If you keep air pressure to not over 70 PSI, it doesn't break up and will last a lot longer. For heavy rust, use one of the abrasive media.
Old Feb 4, 2009 | 01:08 PM
NMT1957's Avatar
NMT1957
The black beauty will cut faster and leave a slightly rougher surface. It also makes more dust in a cabinet and is harder to see. If you hook up a shop vac hose to the upper rear corner of the cabinet it will help with the dust removal. A light of some kind is good to have in the cabinet too. I used glass beads on all of my parts in the cabinet. It does breakdown faster with higher air pressure and doesnt cut as fast as black beauty.
Old Feb 4, 2009 | 02:28 PM
Steve COSD's Avatar
Steve COSD
I agree with this. If your blasting aluminum the glass media works very well. After I clean or blast an aluminum part I spray it with the high temp clear from eastwood. TP tools or TIP tools has what you need.
Good Luck
Old Feb 4, 2009 | 02:56 PM
70BBvert's Avatar
70BBvert
Danny
Black beauty will remove heavy rust quickly, but will leave a rough finish. I use Aluminum Oxide for steel & heavily rusted cast parts. Final cleanup of the cast parts with glass bead and glass bead on aluminum parts.
Clean & degrease the parts first and the media will last longer & it will be easier to see. Also I wire wheel the heavy rust and any scale off first.
Jim
Old Feb 4, 2009 | 03:41 PM
Jeffsvettes's Avatar
Jeffsvettes
Walnut shells for aluminum. It doesn't etch the aluminum like glass beads do.
Jeff
Old Feb 4, 2009 | 04:18 PM
Dustup7T2's Avatar
Dustup7T2
Terrorizing Orange Cones
Jim
I use a 70 grit alum oxide in my cabinet. Shop vac connect to suck up dust and parts come out finished like new, ready for wash-dry and protective coating of your choice.
Old Feb 4, 2009 | 04:32 PM
hicswa's Avatar
hicswa
Thanks,
Danny
Old Feb 5, 2009 | 01:45 AM
Prestige593's Avatar
Prestige593
You are probably going to call me crazy because that's exactly what I thought when I was told the following..... I was restoring the seats in my '77 and wanted to get all the old rust and paint off. I went to Wal Mart and bought one of those long flat plastic, under the bed storage boxes, and 6 gallons of vinegar. Sounds crazy, but trust me, after about 36 hours in that bath, those frames and tracks came out better than any sandblasting job. Shot it with a high pressure garden hose and down to the bare metal. Here is a before and after pic. I used spray paint primer and flat black to finish them off. Good Luck.
To help with sandblasting media
