Calipers? Not again?!
Old Feb 6, 2009 | 10:04 PM
curving_edge's Avatar
curving_edge
Default Calipers? Not again?!
Hopefully you guys can help me....
First thing is first. I need brakes bad! All new calipers from Advance and they are leaking...again. I heard LoneStar is very good. Is this true?
Secondly: I drilled out my front two hubs so I can put new rotors on...BUT do you have to do that to the rear two hubs also? How hard is that?
Im tired of leaking calipers! My vette is rear end is 'popping' around corners. (only when the brakes are applied) brakes are grabbing....
Im just gettin frustrated....taking a break tonight....
Old Feb 6, 2009 | 10:12 PM
mrvette's Avatar
mrvette
DO NOT drive that car outta the driveway until you find out EVERYTHING about that entire rear suspension and bearings, brakes.....i'ts a bit of doing, being independent rear.....
Old Feb 6, 2009 | 10:18 PM
curving_edge
I know the rear suspension is tired. And i believe the rear end needs to be rebuilt or replaced. But i know that the front left caliper is leaking. as soon as i saw this, all the problems started coming into play.
Obviously, calipers are the 1st thing to go....just need to know if Lonestar is good i guess.
You guys know more about this than i do.
Old Feb 6, 2009 | 11:45 PM
Steve COSD's Avatar
Steve COSD
You need to get the O ring type seals on the pistons in the calipers. If you want to do it once and forget it you need to do it right. Sooner or later you get what you pay for. Check out the O ring design calipers from Vette Brakes and Products. As far as the rear end. That noise could be U joints and or the clutches in the rear end. I would change the gear oil in the rearend and add one and a half bottle of additive for the clutches. Your local GM parts knows all about this stuff.
Good Luck
Old Feb 7, 2009 | 07:39 AM
mstanton's Avatar
mstanton
I bought a single caliper for my 70 a few years back. I ordered it from a major supplier but it came in a Lone Star box. It was a good quality caliper that I have been pleased with.
Recently I ordered 4 calipers for my 65 from VBP. The calipers were great and the core refund fast. I only wish that I got them powder coated.
Old Feb 7, 2009 | 08:30 AM
guappy's Avatar
guappy
You might want to try Muskegon Brake before you buy anything.I've used there cal. and rotors and brake kits on a few vettes and there stuff is good at a pretty good price.
Old Feb 7, 2009 | 09:36 AM
Fonz69's Avatar
Fonz69
This option is pricey but Wilwood has come out this year with direct bolt on calipers for the c3 will fit over your stock rotors
I spoke with a manager at Wilwood and he said they just introduced them at the sema show.
Also on page 12 April issue Corvette Magazine
Old Feb 7, 2009 | 09:52 AM
Binnie77's Avatar
Binnie77
I am in the process of installing the Wilwood direct fit calipers right now. They sure look 'sweet'
My Wilwood Install
Old Feb 7, 2009 | 10:23 AM
66CorvetteCoupe's Avatar
66CorvetteCoupe
Default Lonestar
Derek,
I put Lonestar Calipers on my 68 4 years ago and they have worked flawlessly. My car sits a lot which kills those things. Good luck with your brake problems. You say your rear end pops going around corners; have you changed your fluid in the rear end and added the proper additive for the posi unit? You may find that's causing the popping as well.
Old Feb 7, 2009 | 01:24 PM
curving_edge
Thanks for the replies. I will do some research on wilwood and their 'bolt-on' applications. I think im going big on this one.
Braking is a big issue....
The rear-end, i havent serviced it in 10k. I wouldn't think it has any problems.....but all i used was GL-5. I didnt put any additives in there. That is what the chevy parts guy told me here in kansas city.
Hopefully im not in a pickle.
Old Feb 7, 2009 | 06:21 PM
killain's Avatar
killain
Oldtimer
I put a set front and back of 'O' ring calipers from VB&P and NEVER had a single problem from then on. Brakes worked great year after year. Just noticed their having a 20% off sale till the end of Feb.
Old Feb 7, 2009 | 07:42 PM
curving_edge
Originally Posted by binnie77
i am in the process of installing the wilwood direct fit calipers right now. They sure look 'sweet'
my wilwood install
how much did those bad boys cost? I'll buy em' right now!
Old Feb 8, 2009 | 12:56 AM
Droptop-Rob's Avatar
Droptop-Rob
As to your second question:
Once you remove your rear wheels, you will have to inspect to see if the original rivets have been removed or not. They did come from the factory riveted as the fronts did. good luck.
Rob
Old Feb 8, 2009 | 04:53 PM
Sky65's Avatar
Sky65
St. Jude Donor '05, '09, '15
If you have an open diff you are fine . If you have a posi that is probably your noise. I used two bottles of the gm posi additive.
To Calipers? Not again?!
