ok i need engine info, advice and help ::AAGH::
:will y:
so i started up the corvette and i havent really had time to look at the engine but seems like ill have to replace the gaskets (hopefully tahts all
)anyways, here aare two pics from the top side (ill ask later about the leaks underneath xD)
that GUNK smokes after running for a bit, looks like its oil right? gasket problem? or is the oil coming up the bolts? or both? :S
also:
what is THAT? i dont think its fuel.. didnt really check it though to be honest :S and looks like the gasket/sealer is starting to ooze out right? or is it supposed to look like that?
anyways, i appreciate ALL help and advice (except for "scrap it" without a good reason)
the engine still has power in it
i drove it from seattle to portland without any problems (about 160 miles) so im hoping its just a gasket issue... also, in the first pic as well as the second pic, you can see some of the paint peeling. if i get to replacing the gaskets (if thats what needs to be done) then is there some kind of paint i can spray (after sanding it down) to give the engine a clean look? ill probably have this engine for 1-2 years (as soon as i pay off some C.Cards, im hoping to buy an ls1)
thanks agian and i look forward to reading some replies
does anyone have any suggestions on what type of gaskets/sealer to get? ill probably replace the intake/valve gaskets and while im down there, ill see if i need any others :S
meanwhile. thanks for the help tyler
and dont worry
im a painter by trade
i mask EVERYTHING ^^
If it was me, I believe I would drive her for a while before I got neck deep in a major overhaul.
Good luck.
Cars this age usually need a few things like hose gaskets etc. Dont freak. Its not that bad
