gas tank papers
Old Feb 22, 2009 | 07:45 AM
cruise83's Avatar
cruise83
Default gas tank papers
I hear a lot lately about the documents that may or may not be hidden on top on my gas tank. what info is on these papers? I have a 79, can you get them without dropping the tank?
Old Feb 22, 2009 | 09:03 AM
xCCTer's Avatar
xCCTer
CF JASOC Member
From: Downtown Annapolis, MD. The Future is where we all have to live. Let's not screw it up.
You have to drop the tank to remove it if it's there. Here is one of the better examples I've seen. It's the build sheet for the car as it moved down the assembly line.
Old Feb 22, 2009 | 09:41 AM
Bobz08C6's Avatar
Bobz08C6
I "carefully" removed mine from my '79 by removing the gas tank filler door and rubber filler piece. It is at about 10:00 position. Obviously it is very fragile and is held in place by a strip of glue so be careful. As mentioned it is easier to drop the tank enough to get your hand up on top of the tank but I did it the easy way.
Here is some tank sticker info in the attached document. Since you have a '79 you can get a copy of your original sales invoice from here.
http://www.corvetteactioncenter.com/...x.php?cmd=area
With a tank sticker or sales invoice you can get an accurate window sticker replica from here.
http://www.window-sticker.com/
Old Feb 22, 2009 | 04:31 PM
cruise83's Avatar
cruise83
Very much appreciate the information!! I will try the easy way first..
Old Feb 22, 2009 | 08:08 PM
cruise83's Avatar
cruise83
was wondering if I could get the sticker with just the VIN number? I finally was able to confirm my numbers match. see the pics...number 28182
Old Feb 22, 2009 | 08:43 PM
cruise83's Avatar
cruise83
well did what Bobz said, removed the gas door and the rubber collar, looked about 10 o'clock on top of the tank...and all that was left was the glue and few pieces old crusty paper. It was like going on a treasure hunt with a map only to find someone beat you to it..
Old Feb 22, 2009 | 09:01 PM
avalonjohn's Avatar
avalonjohn
CF Community Team
Veteran: Marine Corps
St. Jude Donor '25
save the crusty paper......it's what is left of your sticker and adds to the originality of your car.
Old Feb 22, 2009 | 09:20 PM
Bobz08C6's Avatar
Bobz08C6
Yeah, save the crusty pieces of paper. Any chance the VIN is on one of those crusty pieces of paper? There is also an outside chance that the missing parts of the sheet have shifted to another part of the tank top or somewhere nearby. The only way to know for sure at this point is to drop the tank.
The good news is that now with the VIN you can get the sales invoice from Allied Vaughn and with the sales invoice you can get an accurate window sticker replica from Triple A enterprises window-sticker.com.
Old Feb 23, 2009 | 01:23 AM
vettebuyer6369's Avatar
vettebuyer6369
Um, generally we do this before buying the car.
Old Feb 23, 2009 | 08:20 AM
Vette79C3's Avatar
Vette79C3
Old Feb 23, 2009 | 08:59 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Having a tank sticker is nice, but you will find more information on the dealer invoice, including the original dealer, cost, when the car was shipped and when it was expected to be received, all the options, colors, etc.
Contact Allied-Vaughn. It's worth the $50 if they have your VIN in their records.
Old Feb 23, 2009 | 09:11 AM
C3bdj1's Avatar
C3bdj1
St. Jude Donor '10
If you want to have a "window sticker" made for your car, you will need more than just the VIN.
For it to be correct, you need to supply accurate information on what options originaly came on the car, and the name of the Chevrolet Dealer the car was shipped to.
All this information is available thru "Allied Vaughn" in the form of a copy of the original "dealer invoice". This will cost you $50.00. ( got mine, well worth it). You can then use this to have a reproduction "Window Sticker" made for your specific car.
The links Bobz08C6 gave you will get you what you need/want...unfortunately, a "copy" of the original invoice and a "reproduction" window sticker is not as desirable as having the "real" build sheet. But they are still cool to have.
(opps...Easy Mike beat me to it...)
Bobby
Old Feb 23, 2009 | 08:45 PM
cruise83's Avatar
cruise83
I have learned so much about owning a Corvette and loving the experience, the Forum has been a part of that. The folks on the forum truly like helping everyone through their issues and sharing information. The greenhorns can learn from the seasoned vets. So I hope we are welcome to share our learnings. I had no idea what "matching numbers" meant, now I do. I can bet you that the process I go through to buy my next vette will include checking this and many many more lessons learned.
To gas tank papers
