Spark Plug Wires
Old Feb 23, 2009 | 07:47 PM
JimT's Avatar
JimT
Default Spark Plug Wires
Does anyone have any tips on installing wire ends on custom type spark plug wires. I've done this several times and never had any problems before. I just bought a set of Taylor 8mm plug wires and am cutting them down to fit. I'm having one heck of a time pushing/pulling the wire through the distributor end sockets. I'm using a little dialectric grease but the fit is still so tight I can't get them through. Any ideas? Can you heat the sockets for ease of installation? Soak them in something? It looks like the manufacturer uses one size socket for both 7mm and 8mm wires, so the larger wires are almost too tight.
Old Feb 23, 2009 | 07:59 PM
c3corvette77's Avatar
c3corvette77
I have Taylor custom fit 8mm wires too. If you follow the intructions they give, you will go through every 4 letter word in the book, I know I did. I read a tech tip in Hot Rod about cutting the wires to length, crimp on the terminal then slipping the boot over the crimped on terminal, works like a charm and is way easier on your fingers and passers bys ears.
Old Feb 23, 2009 | 11:08 PM
my 76 ray's Avatar
my 76 ray
Wow! Talk about perfect timing. I just bought a set on Friday. Thanks for the post.
Old Feb 24, 2009 | 12:14 PM
BTAL's Avatar
BTAL
St. Jude Donor '09
What are you using to crimp the connectors? The special tool listed (recommended as an upsell)? I gave up on one set and went with pre-attached boots, but don't like the extra length on 2-3 of the wires.
Old Feb 24, 2009 | 02:02 PM
JimT's Avatar
JimT
Well, I finally finished the job. Thanks for the tip (cut/crimp/ then slide on the boot), Although "works like a champ" is a bit of an overstatement, it was definitely easier than the instructions. I used silicone as a lubricant and a pair of long thin needle nose pliers to help push the wire/crimp through the boot. And you are correct about the four letter words and colorful phrases - I went through them all!
For crimping, I purchased a crimper made by Taylor ($15) from Summit. There are many crimpers out there and most are very expensive, but the Taylor worked OK.
Old Feb 24, 2009 | 10:37 PM
c3corvette77
i just used the crimper from summit. a little WD-40 and my boots slipped over the terminals really easily. just make sure you don't try and slid the boots onto the wire, crimp the terminal then try and slide the boot back over the terminal, you'll be there all day. Cut, crimp, then slip the boot on over the crimped on terminal.
Old Feb 25, 2009 | 06:01 PM
NMT1957's Avatar
NMT1957
Do the 8mm wires fit in the standard wire supports ? Say Yes !!!
Old Feb 25, 2009 | 08:16 PM
JimT's Avatar
JimT
The 8mm wires do fit the wire supports. In fact they fit a little tight which is good - they don't slide around, they stay in place.
Old Feb 25, 2009 | 09:55 PM
NMT1957's Avatar
NMT1957
Great thanks, my engine builder is making a custom set. I can change them out to originals after restoration is complete and engine has been through its paces. He doesnt trust the stock ones.
Old Feb 25, 2009 | 10:02 PM
Glassbowtie77's Avatar
Glassbowtie77
What did you guys use to strip the end of the wire without cutting into the core and damaging the conductor?
Old Feb 25, 2009 | 10:37 PM
c3corvette77
i connected the wires at the plug end and routed them where i wanted. then used wire cutters to cut the wire to length at the distributor, go a couple inches longer than you think, you can always trim a little off, good luck making them longer. i then used a scrap piece of wood as a work surface and carefully cut the insulation radially using a sharp razor blade then slipped the insulation off the core wire. you shouldn't damage the core wire if you're careful. might be easier if you have a buddy help. 2 sets of hands. i followed firing order.
Old Feb 25, 2009 | 11:15 PM
Glassbowtie77
I was just playing around with the coil wire they give you (don't need it with the HEI) and tried using my wire stripper with the wire in the 14 gauge slot. It made a nice clean cut and didn't nick the conductor wire at all. The conductor fits good in the 14 gauge hole on the wire cutter and leaves just a little play around it, should work out good.
Old Feb 26, 2009 | 12:11 AM
chvet73's Avatar
chvet73
WD40 and a good crimper= no problems.
Old Feb 26, 2009 | 11:08 AM
Red Rochester's Avatar
Red Rochester
Veteran: Coast Guard
To Spark Plug Wires
