rear camber rod question
Old Mar 1, 2009 | 12:26 PM
temvette72's Avatar
temvette72
Default rear camber rod question
I noticed that my rear tires were wearing inconsistently, and I hear a clunk coming from the rear when I hit a bump. I decided to pull the rear camber rods off and replace the bushings. On the inboard side of the rods, the "lipped washers" were missing on one side (probably the source of the clunk) and very rusted on the other. Does anyone have a better idea than those lipped washers? That little surface that the adjustment bolt rides on seems pretty skimpy. Any ideas? I wandered the hardware aisle at Home Depot, but couldn't come up with anything.
temvette72
Old Mar 1, 2009 | 12:36 PM
cargo247's Avatar
cargo247
this is the best way to go IMO.
http://www.parts123.com/parts123/yb....Z5Z5Z50000050G
Todd
Old Mar 1, 2009 | 02:11 PM
temvette72's Avatar
temvette72
Todd
I like those, but I had a set of urethane bushings lying around, so I cleaned up my originals and installed the new bushings already. Is that new through-bolt on the adjustable arms bigger so it will be a snug fit through the bushing, or does it use lipped washers also? Thanks.
Temvette72
To rear camber rod question
