Converting to Power steering.
Old Mar 4, 2009 | 05:13 AM
Anthony Galvin's Avatar
Anthony Galvin
Default Converting to Power steering.
Hi Guys and Gals,
I have just ordered a power steering conversion kit from ecklers to upgrade a 71 coupe to power steering. This is a complete kit. I was wondering if anyone has used this kit and carried out the conversion on their own car? and if so was there any problems post fit. Any advice greatly appreciated.
cheers,
Tony
Old Mar 4, 2009 | 09:26 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
I have not used the kit. The AIM will show the factory power steering installation and will probably help with your kit install.
Buy or rent a pitman arm puller.
Good luck.
Old Mar 4, 2009 | 10:30 AM
Douglas Mariani's Avatar
Douglas Mariani
GM Cert Corvette Tech
Pro Mechanic
I installed the conversion kit on a 69 with no problems. Bolting in the ram sapport brace is a little bit of a PITA,besides that its an easy conversion.
Old Mar 4, 2009 | 12:47 PM
70Yellowbird's Avatar
70Yellowbird
I just looked at Eckler's PS kits and the only item that appears to be missing for the conversion is the belt ... which you can purchase locally if you didn't order it.
Good luck.
Old Mar 5, 2009 | 05:15 AM
Anthony Galvin
Thanks Guys,
I will let you know how things go. Looking forward to getting the car out of winter storage in about 5 weeks time. I find the weather here in Ireland can be quite harsh on the chrome bumpers!!
Old Mar 5, 2009 | 11:55 AM
l1dws's Avatar
l1dws
Bought the Ecklers kit and the install went very smoothly. Have the AIM did help. Good luck
To Converting to Power steering.
