Tach/Speedometer access
Old Mar 22, 2009 | 08:04 PM
ahough76's Avatar
ahough76
Default Tach/Speedometer access
I need to replace the light bulbs behind the tach and speedometer in my 69 vette. Does anyone know how to do this? Any help is appreciated, thank you.
Old Mar 22, 2009 | 08:51 PM
QuicheLorraine's Avatar
QuicheLorraine
You need to pull the dash to get back there. Right side lower comes out first, then the center. Next remove the dash pad from the top and finally you can get the instrument cluster out. While it's out put a new circuit board in the tach.
Old Mar 22, 2009 | 09:01 PM
Willcox Corvette's Avatar
0Willcox Corvette
Former Vendor
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
Here this will help you! And yes the best way is to remove the passenger side, then the upper and then the left pad. http://willcoxcorvette.com/repairand...lp.php?hID=105
Willcox Inc.
Old Mar 22, 2009 | 09:03 PM
DZRick's Avatar
DZRick
There is no circuit board in a 69.
I see that Willcox has you covered.
If you need to see a picture of the back of the dash, let me know.
Old Mar 22, 2009 | 09:27 PM
0Willcox Corvette
Former Vendor
You know, once you have the upper out you could probably reach in and do the bulbs. It's been a while since I did this job my self, but I think you should be able to get in there with the right and upper moved. . .
Willcox
Old Mar 22, 2009 | 09:46 PM
Big Don's Avatar
Big Don
I recently took my drivers side dash out of my 69 and did not have to take out the center console. I recomend you buy a Assembly Instruction Manual (corvette central, etc.) which decribes the procedure. Basically you have to remove the little panel on the left front of the console - 1 screw. Then the dress panel under the steering column -3 screws. Then lower the steering column - easy 2 bolts. Then remove screws all around the left dash pad - 8 I think. Then you can pull the whole dash speedo and tach assembly out a couple inches and pull it down. Then you can get your hand in over the top and reach the back of the tach or speedo. Each has 4 general light sockets plus turn signal etc. lights. The general illumination sockets use gray wires. Others are various colors. Pop our the sockets. pull them out and replace the bulbs, then snap them back in the same place. You don't have to disconnect the tach or speedo cables. Be careful you don't disturb all the other connections and vacuum lines behind the dash. Before you put the dash back, start the car and make sure EVERYTHING works.
To Tach/Speedometer access
