Removing Rear Rotors
Old Mar 22, 2009 | 10:12 PM
21boy's Avatar
21boy
Default Removing Rear Rotors
Hi everybody, I need to replace the original disk brake rotors (rear) on a 74'. I replaced the fronts with little problem, but I really have no idea how to go about getting the back ones off.. The rear caliper seals where original which I thought neat because they've lasted for a good 20 years functionally. But anyway, yea any input on how to get these things off is appreciated.
Old Mar 23, 2009 | 08:42 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Originals are riveted to the rear hubs. Index them so you can reinstall them in the exact position for run-out purposes. Drill out the rivets, ease the parking brake shoes, then get the calipers out of the way.
Chassis and Service manual helps.
Old Mar 23, 2009 | 08:42 PM
21boy's Avatar
21boy
I have "A" service manual, a being the key word because the cover has been ripped off.. but it really lacks in detail about some specifics.. This being one of them. But thank you very much that helps a lot!
Old Mar 23, 2009 | 08:51 PM
wfo76's Avatar
wfo76
This thread has some pics...
http://forums.corvetteforum.com/c3-g...r-removal.html
Old Mar 23, 2009 | 10:54 PM
21boy's Avatar
21boy
Thanks again guys. How big of a problem is it if the rear rotors aren't perfect? Front are, brakes are all being reworked but was curious to know what if the back ones where only partially done? Heating and faster wear on pads? They don't look that bad, but they're still rusted a little and original..
To Removing Rear Rotors
