Hurst VS Stock
Old Mar 23, 2009 | 11:03 PM
vett us all's Avatar
vett us all
Default Hurst VS Stock
Am thinking of replacing my factoy 4speed shifter and linkage and installing a Hurst 4speed shifter and linkage. Would there be that much difference in the quality and reliabilty on the performance of such a swap? I do not know, would like to hear from guys that have done such a swap. I already have the Hurst set up for my 73. M21 4.11 550+ HP on the motor. Thanks
Old Mar 23, 2009 | 11:07 PM
another-user's Avatar
another-user
its a night and day difference between the two. put the hurst on it.
Old Mar 23, 2009 | 11:47 PM
CoolShark's Avatar
CoolShark
It all depends on whether you want tight shifts or slop.
Old Mar 23, 2009 | 11:50 PM
TimAT's Avatar
TimAT
If you think you might ever do any serious shifting, get the HURST Competition Plus. Adjust the gear stops per the instructions. The original shifter is not up to repeated hard shifting. And the gear stops prevent you from "overtravelling" the synchro rings and stretching them, so they live too.
Old Mar 24, 2009 | 12:55 AM
gbvette62's Avatar
gbvette62
The Hurst is the only way to go. If you want to keep the stock appearence, spend the extra $89.00 and by the stock appearing shifter that bolts to the Hurst linkage. This is the best of both worlds, it looks like a stock shifter, but you can actually enjoy shifting it!
Old Mar 24, 2009 | 01:18 AM
rcread's Avatar
rcread
On a scale of 1 to 10, the Hurst shifter is a 3. This makes it 3 times better than the stock shifter, which is a 1. I say go Hurst.
Old Mar 24, 2009 | 02:25 AM
TimAT's Avatar
TimAT
I need some edumacation- if, on a scale of 1 to 10 Hurst is a 3? What else is there that's available for a Muncie trans that will fit in the stock location on a C-3? I'm all ears here. I've been using Hurst for close to 40 years. If there's something better, I'd like to know, cause I'll be spending some bucks soon!
Old Mar 24, 2009 | 07:45 AM
vett us all
I do have the stock looking shifter. Thanks for all of the positive replies from you guys that own and shift with the Hurst. I will be joining you pretty soon.
Old Mar 24, 2009 | 08:55 AM
GD70's Avatar
GD70
Here's a short video of my hurst shifting on some local roads. The shifts are short very crisp.
Old Mar 24, 2009 | 09:55 AM
CCrane65's Avatar
CCrane65
I don't know about any of you guys but my factory shifter used to hit the shifter plate on 1 and 3 shifts. The Hurst with the factory look handle doesn't even come close.
And it feels so tight (vs. sloppy) and accurate you'd never want to go back.
I rebuilt my original shifter for the next owner, not myself.
cc
Old Mar 24, 2009 | 11:15 AM
Ironcross's Avatar
Ironcross
I had one offered to me and installed free of charge and never took George up on it at one of the 'Indy' Nationals for my 62. They may have improved over time, but I never liked them. And yes I know they became OEM on some Pontiacs and Olds pieces....
Old Mar 26, 2009 | 01:35 AM
vett us all
Thats what I'm talking about.
To Hurst VS Stock
