Proportioning valve
Old Mar 25, 2009 | 08:08 AM
Kahle76's Avatar
Kahle76
Default Proportioning valve
Can you test this part? While I'm replacing the master cylinder I thought I would take look. Can it be cleaned? Do they go bad?
Thanks.
Old Mar 25, 2009 | 08:14 AM
joewill's Avatar
joewill
Old Mar 25, 2009 | 10:26 AM
Duke94's Avatar
Duke94
You can test the differential section (the part that turns on the failure light) by opening a bleed screw and applying pressure. It could take 3-400 PSI to trip it so you can't do it with an air hose on the bench. You can remove the switch and differential piston to check the o'ring seals, but the proportioning section (the big nut on the end) is pressed together. I have attached a pic of the prop section disassembled so you can see what's in it. If it were me, I'd replace it since the seals will be flat and prone to leak due to age. The proportioning section could be tested on the car with a couple of 1000 PSI gauges. Install one gauge at a rear brake and one at the master cylinder outlet and apply the brake to about a 1000 psi at the MC. If the proportioning valve is working, you should get about 600 PSI at the rear wheel.
Old Mar 25, 2009 | 05:26 PM
my 76 ray's Avatar
my 76 ray
I once had a Camaro that I couldn't get a good pedal on even though I had bled the brakes multiple times. Replacing the proportioning valve allowed me to bleed the brakes and get a good pedal. I don't know how to test it but I would say they can go bad.
To Proportioning valve
