1980 body mounts
Old Mar 25, 2009 | 04:18 PM
Grumpy 427's Avatar
Grumpy 427
Default 1980 body mounts
ok after looking at these today, it appears that there is no way to get them out unless you lift the entire body off the frame? Is this correct or is there a way to do this I am thinking i have bit off more than i should of with this vette? This pisses me off, there is nothing easy about these cars.
Old Mar 25, 2009 | 04:23 PM
Go Vette Go's Avatar
Go Vette Go
2024 C3 of the Year Finalist- Unmodified
St. Jude Donor '10-'11, '15, '19
Grumpy - you don't have to remove the body to change the mounts. Send me a PM with your email address and I will send you and article I scanned from one of the popular Corvette rags. Great step by step directions (with pictures)
I used their process on my 76 & 78 Vettes with great results.
Old Mar 25, 2009 | 04:27 PM
Ak. Mal's Avatar
Ak. Mal
From: Kansas City, MO ...I'd like to go fishing and catch a fishstick. That'd be convenient. - Mitch Hedberg
Here is one of the best threads we've ever had on the subject.
http://forums.corvetteforum.com/c3-t...with-pics.html
Old Mar 25, 2009 | 04:29 PM
Grumpy 427's Avatar
Grumpy 427
PM sent. Thanks for the replies.
Old Mar 25, 2009 | 08:04 PM
Grumpy 427's Avatar
Grumpy 427
Ok how do you get this one out? Pass rear. The nut is spinning so now what has to come apart to replace it?
Old Mar 25, 2009 | 09:03 PM
stefbedard's Avatar
stefbedard
1st Gear
the nut is spinning in the cage nut, you are in big trouble, the only way the get the bolt out will be to cut it, and you must repair or change the cage nut before istall the new one.
dont know if you will be able to lift hight enought to do it without lifting
the entire body
Old Mar 25, 2009 | 10:01 PM
Grumpy 427's Avatar
Grumpy 427
I will have to cut it 2 times i think once to get the head off, then again to shorten it after i pull the bushings off.
Old Mar 26, 2009 | 12:41 AM
pepegriffo's Avatar
pepegriffo
Hi, Do a search on the forum, on body mounts. There are several great posts on this.
For #3 mount acess you need to cut the panel near the top where there is an indent, then down the sides. You can then have a good view of the mount. You can also jam the nut to stop it from spinning. Also makes it simple to install new mounts.
My Bad 79, member has great photo's. I have a copy if you can't find the post.
Pepe Griffo
Old Mar 26, 2009 | 12:48 AM
Grumpy 427's Avatar
Grumpy 427
What panel do i need to cut? Can you post some info please.
Old Mar 26, 2009 | 12:57 AM
pepegriffo's Avatar
pepegriffo
Hi, The pic that was posted, about 2" above the opening cut horizontally. Then cut down both side to the bottom. You will need to do this to have access to the mount. It can be easily installed back in place with epoxy and some cloth. send me PM i will send you a copy of the pic's I mentioned previously.
Griffo
Old Mar 26, 2009 | 02:01 AM
Grumpy 427's Avatar
Grumpy 427
Pepe Griffo
The search feature is awefull. I type in body mounts. And i get posts about stereos? WTF and wiring?
Old Mar 26, 2009 | 11:11 AM
Grumpy 427's Avatar
Grumpy 427
Hey Griffo, can you send those pictures please.
Old Mar 26, 2009 | 04:49 PM
Grumpy 427's Avatar
Grumpy 427
Ok 6 out 2 to go. Just the ones in the kick panels. Any ideas? before i get on those.
Here are the pics of what i had to cut off the body to get the #3&6 mounts out one side came out the other had to have the bolt cut twice.
BEFORE
After cutting body.
I am assuming that after all the bolts are out, i can lift the body 3-4 inches per side to get these bastards out right?
Old Mar 26, 2009 | 11:49 PM
Grumpy 427's Avatar
Grumpy 427
Bump
To 1980 body mounts
