when i turn my wipers on the wiper door opens but nothing happends . i replaced the wiper motor thinking that was the problem. Iam not sure if the wiper door limit switch is working. seems like thats where the problems is but im not sure how to test it? Im confused BUT whats new ....Thanking you in advance Ray
When the door opens an electrical switch on the engine side of firewall is activated by a rod to release the wiper arms. Is it adjusted correctly to depress the switch? Find plug and see if current is running through (ammeter or such)
The Wilcox diagram is very helpful (although no one answered my email). I just went through something similar, but my door did not open. Make sure that the red from the limit switch is hot. The power always is on to the motor and you are switching the ground. There is also a black wire to the motor. Make sure it is a ground.
