From: Minnesota in the summer, Las Vegas in the winter
I'll jump in on some of this..............
starting with #4:
Depending on your level of mechanical expertise, yes, you can take these off with the equipment you listed. I refurbished/ rebuilt everything last year from the driveshaft back. My 72 had about 75000 actual miles on it so I just had the differential inspected by a pro. They changed the seals while they were in there. I had to buy one trailing arm, but the other one was fine. Again, I had a machine shop disassemble and rebuild the arms. But I did all the rest myself: new u-joints, brakes, emergency brakes (installed by the shop), calipers, spring, struts, shocks, etc. I removed the arms and reinstalled them by myself. They came off easily and went back on without too much trouble. Then I had alignment done.
Trailing arms are a moving part of the framework. They connect the halfshafts coming from the differential to the wheels. Supported by the arms are the brakes, emergency brakes, shocks, rear spring and wheels.
I spent around $1000 and took almost 6 weeks doing this project.
Please remember that it takes a lot of work to get them from their original position, to the floor. I used a can of PB blaster and an air hammer. Other guys have used a saws all to cut the bolts holding them in. Either way, it's not an easy task. Then it takes some special tools to pull them apart and rebuild them. I don't have the tools so I took them somewhere and had them done.
Hey you guys, I just bought a beautiful set, with rotors and all, from Jacobs Corvette's in Coraopolis, PA. Mr. Harvey does a out of site job. I know that there a lot of good people rebuilding them. Look at his work, been in business for 30 years. Doctorgene
you will need
a sawzall...with some good metal blades
pentetrating oil
some duct tape.... after you bust up your knuckles a few times...
are you just getting new t-arms with bushing or also wheel bearings too
I haven't decided if mine need immediate attention, to be honest. We replaced the rear leaf spring and adjusted the camber of my rear wheels, and while doing so noticed my trailing arms looked horrific. Everything else looks decent and I'm wondering if I need to jump into the trailing arms just because they look crusty in comparison to the rest of the vehicle now. I do need to have the wheel bearings redone soon. There's a bit of play in my wheels, but no clunking or weird noises. I was hoping to get a complete set with the bushings as well, but don't want to start the project if it's going to be over my head.
so does anybody know when they NEED to be replaced?
Ditto... are there any signs to look for other than cosmetic? I had my frame powder coated, and next to my frame they look awful, but I haven't noticed any performance issues.
If it hasn't already been done, then it needs to be done.
