window switch options
Old Mar 26, 2009 | 08:49 PM
halfshaft's Avatar
halfshaft
Default window switch options
Has anyone updated to a newer electric window switch? Will any other GM switch work? I am going to be moving them to the gauge portion of the center panel and would like to go with a diiferent look than the chrome switches. Any ideas?
Old Mar 26, 2009 | 09:09 PM
Willcox Corvette's Avatar
0Willcox Corvette
Former Vendor
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
You might be able to use the later model switches like from a 84 and up. I don't know how you would mount them.
Willcox
Old Mar 26, 2009 | 09:40 PM
SuprJames's Avatar
SuprJames
I just went with a couple spal window switches. NOt sure if they'd work with the stock motor, but I'm sure you could make them work!
http://www.spalusa.com/store/main.as...&item=33040018
Whatever you do, make sure you install relays.
Old Mar 26, 2009 | 10:29 PM
onaqwst's Avatar
onaqwst
make sure you test the power/amps to the motor. the best thing is to setup a relay and do it that way so all the juice doesnt go through the switch....
Old Mar 27, 2009 | 10:28 AM
halfshaft's Avatar
halfshaft
I have been wanting to do the keyless entry from spal also, as I have no way to lock my car now. Has everyone found the stock window motors to be sufficient?
Old Mar 31, 2009 | 07:19 AM
SuprJames's Avatar
SuprJames
The stock motors are awesome in my '82. They roll the window up and down faster then any car I've owned and they are about 15 yrs. old.
I'm going with Spal for my '72 just because they are CHEAP and I heard they work great.
To window switch options
