Middle Console
Old Mar 28, 2009 | 03:23 PM
Baldwin Brave #77's Avatar
Baldwin Brave #77
Default Middle Console
I have a 1978 Corvette Pace Car. Recently, my clock stopped working and I bought a new one. I was wondering how do I take the middle consloe off without causing any damage.
Old Mar 28, 2009 | 05:42 PM
randommj's Avatar
randommj
on my 74 Ive got to take the top section out first (3 screws) its got the wiper controle on it, Im really not sure what yours looks like, once the top section with the wiper controle and the vents is out there are 3-4 screws on each side and one on the top holding it to either side of the dash pad and the top pad, at that point its "free" but it still a b!tch to get out, you need to push that top air duct back (it connected to the vents that you took out first, just make sure it dosent hold the gague bezzel back) pull the top forward then TRY to lift it all out, mine has a couple bolts that stick down twards the transmition that get hung up EVERY time, and thats what you need to pull over the center shift plate
once you have it out it goes back in super easy, at least mine does, now there could be, and more than likely is, a diffrence in our years, but that should get you started, it should just be held in with a few screws, you dont need to pull anything else out to get it out
Hope that helped a little bit,
Miles
Old Mar 28, 2009 | 06:53 PM
KapsSA's Avatar
KapsSA
Active Streak: 90 Days
A bit different on 77-82.
Remove the carpeted console side panels, 3 screws each side.
2 screws up from below, console to gauge bezel. 1 each side.
Remove the 4 screws from the cluster face, one each side, 2 at the top.(all those allen screws are cosmetic!)
Pull the ***** off the radio and remove the retaining nuts for the radio(they're probably round with slots in them, needlenose pliers works)
Now, I like to remove the screws from the console too, just the screws. Gives you a little wiggle room to work the gauge cluster out. I've even dropped the defroster switch for more room.
Lay a rag over the console under the edge of the cluster to avoid scratching and CAREFULLY pull the gauge cluster forward keeping in mind there's a light housing at the top. When it's free of the dash, reach in back and pull the one large connector from the printed circuit and the connector at the top for the light(heater floodlite).
Remember, it's OLD plastic. Very brittle!
Old Mar 28, 2009 | 07:08 PM
randommj's Avatar
randommj
I figured it was diffrent, but he had no reply in over two hours, so I thought I could at least get him started
Miles
Old Mar 28, 2009 | 07:29 PM
BTAL's Avatar
BTAL
St. Jude Donor '09
Been there, done that, got the tee-shirt.
Will add that is it a bit easier to remove the carpet side panels with the seats removed. Also, if needed, removing/loosening/shifting the center console/shifter section.
Old Mar 29, 2009 | 08:39 PM
Baldwin Brave #77
Thanks for all the hints.
Old May 16, 2009 | 05:20 PM
Baldwin Brave #77
i unscrewed everything that you guys told me to, but it is catchin on the sides and i dont want to put too much force because i will break it. If anyone knows how to fix my problem feel free to respond.
Old May 16, 2009 | 06:57 PM
Baldwin Brave #77
Where are the retaining nuts and what is a better description.
Old May 16, 2009 | 08:29 PM
KapsSA's Avatar
KapsSA
The radio retaining nuts? On the 2 shafts for the *****.
Old May 17, 2009 | 03:03 AM
musashi's Avatar
musashi
Miles
Thanks Miles! I have a 74' and need to play around with mine as well
Tim
Old May 17, 2009 | 09:26 AM
Baldwin Brave #77
How do you get them things off.
Old May 17, 2009 | 05:44 PM
Baldwin Brave #77
I figured out how to take the retaining nuts off, but i still can't get the console out enough to remove the connectors.
Old May 17, 2009 | 05:53 PM
xCCTer's Avatar
xCCTer
CF JASOC Member
From: Downtown Annapolis, MD. The Future is where we all have to live. Let's not screw it up.
Always lots of fun taking the center gauge cluster apart.
Old May 17, 2009 | 06:27 PM
Ganey's Avatar
Ganey
Deep socket, even a short socket by itself will work many times.
For the stereo, I normally remove the pass. side console panel, just the 1 screw in the front will do.
Old May 17, 2009 | 08:51 PM
KapsSA's Avatar
KapsSA
Did you read my entire post, number 3?
The console is the bottom part with the shifter and heater controls. You're trying to remove the center cluster.
Remove just the screws in the console, 2 each side and 2 from the rear into the parking brake cover. That should give you some additional wiggle room to get the cluster out. Might even help to unscrew the heater control and defroster switch.
My intent is to gain as much access so as to not crack anything.
You DID get the 2 screws from the shifter console going upward into the gauge cluster housing?
To Middle Console
