Fat Mat Installed - Pics
Old Mar 29, 2009 | 11:17 AM
eastltd's Avatar
eastltd
Default Fat Mat Installed - Pics
Hy Guys,
Here is my latest effort - FatMat.
I know most people recommend Dynamat for this but I could not justify the additional cost.
It actually took more time then I thought with all the cutting & fitting but at least I can now check it off the list.
I had two 50 foot rolls and used 1 & 1/2 for complete the interior.
I've got lots of pieces left over and 1/2 a roll to double up areas and line inside the doors.
Here are the latest photos:
Old Mar 29, 2009 | 11:22 AM
hammadown's Avatar
hammadown
looks good..............
Hammadown
Old Mar 29, 2009 | 11:26 AM
Eddie 70's Avatar
Eddie 70
Ci 6, 8 & 10 Veteran
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15
Nice looking work. I wish I would have done this to mine when I had the interior out. Where did you wind up picking the Fat Mat up at?
Old Mar 29, 2009 | 11:32 AM
eastltd's Avatar
eastltd
I bought it on-line from a stereo shop in Canada. $186 delivered
Old Mar 29, 2009 | 11:37 AM
Theiskell's Avatar
Theiskell
Nice work on the mat and the jams look good too
Old Mar 29, 2009 | 11:51 AM
rydoc's Avatar
rydoc
Looks good
Is there a need to put down reflectix, for the heat factor, on top of the FatMat ?
Rod
Old Mar 29, 2009 | 11:55 AM
OURSHARK's Avatar
OURSHARK
Good job done, it will make a big difference.
Old Mar 29, 2009 | 11:56 AM
71coupe454's Avatar
71coupe454
wow thats some clean detailed work. good job!
Old Mar 29, 2009 | 12:09 PM
eastltd's Avatar
eastltd
Originally Posted by rydoc
Looks good
Rod
I have never driven the car so I really don't know if I need the reflectix.
My carpet kit came with an underlayment, I have the firewall heatshields in place as well as the tunnel insulator and seal. With the side exhaust I'm hoping I don't need any more but am open to suggestions from those with experience.
Old Mar 29, 2009 | 12:23 PM
rydoc's Avatar
rydoc
You just hear of guys puting reflectix down on top of dynamat, so if FatMat eliminates the need bonus plan.
Just curious....
You are doing real nice job
Rod
Old Mar 29, 2009 | 12:28 PM
78Vette-SA's Avatar
78Vette-SA
You did a much neater job than I did. I'll bet it will be well worth it.
Old Mar 29, 2009 | 03:37 PM
81shark2008's Avatar
81shark2008
looks good i did the same thing, but muuuuuuch cheaper on ebay, how come noone on here ever checks ebay for parts and supplies? you'de be surprised
Old Mar 29, 2009 | 03:42 PM
81shark2008
i put it in mine and it cheap at lows. it was like 20 bucks for the whole roll and had some leftover. not sure how much of a differnce it makes(never had on road) but was advised by all restoration forums and local upholstery and paint supply shops, it doesnt make that much of a differnce under gas pedal and stuff and makes easy to bond carpet too. the adhesive loves it, either way i would rather have it and not need it than find out you should have it after its all back together, right?
Old Mar 29, 2009 | 04:16 PM
Paul L's Avatar
Paul L
Just curious. What is the purpose of FatMat and all that work?
Old Mar 29, 2009 | 05:05 PM
eastltd's Avatar
eastltd
The primary purpose is sound deadening. The hope is that it will tighten the interior up, reduce squeaks, rattles and create a good environment for the sound system.
I thought I saw you using it with your kick panel speakers Paul and assumed you installed it in the 74.
battsup's Avatar
battsup
It makes the cabin of the car quieter. (cuts down on road, exhaust and engine noise)
Old Mar 29, 2009 | 05:19 PM
Paul L's Avatar
Paul L
I used DynaMat on the kick panels as it is supposed to prevent sound on the back side from cancelling out sound from the front side through the panel perforations. But with a stock exhaust system and with air turbulence in a convertible there is no road noise, just wind. The Windjammer cuts much of that out. Anyway, I was just curious. Some people put on side exhaust, some people put on chambered pipes, some use FatMat or Dynamat. Interesting hobby! Thanks for the answers.
To Fat Mat Installed - Pics
Old Mar 29, 2009 | 06:12 PM
mrmarchuk's Avatar
mrmarchuk
yes, i installed it and it quiets the car down ALOT
look on ebay, i got 100 square feet for $120 shipped with a mini roller, i never used the roller, i did everyhting with a heat gun and gloves, it works ALOT better
that's Additional, fatmat is for sound, reflectix is for heat (it does very little for sound) so yeah... i personally am not going to put reflectix in, if i need to, ill put it in later, it only takes about 15 mins to take out the interior anyways.. as for fatmat, it did an AWESOME job of quieting the car down, im even considering lining my T-Tops with it because when im driving, the t-tops are the ones making the noise now
Old Mar 29, 2009 | 06:21 PM
GD70's Avatar
GD70
Impressive work! Your Vette is coming along nicely.
Glenn
Old Mar 29, 2009 | 11:53 PM
jrl77's Avatar
jrl77
REALLY NICE WORK !
And it will be well wurth the effort, I did my rear compartment before the speaker installation and next winter I'll do the rest. Hopefully as well as you did your's
