Hello. New to the forum. I would like some help to find out what engine I have,I have a 1978 CP light blue. auto that I will be repairing over the year or so, and would like to know what i`m working with. I have been reading this forum for a while now and have repaired quite a few things thanks to the members here. The block code is V09I8TBD I looked this up and there was three possibilitys. So I looked up the casting number 3970010 and this wasen`t very specifc. 1969-1979 low HP 185 High HP 370 2/4 bolt main car/truck/vette If this is an L-48 is it that bad of a moter? good things,bad things about it. thanks in advance tefishe.
I'm no where near being a pro as I'm stumbling along like others - but the V09I8TBD seems like an odd engine suffix/code. I don't see the TBD code listed for a 78 in the Black Book or web sites online that have engine codes.
Thanks for the replyes.
I don`t know if it`s a numbers matching car. The vin #1Z87L8S 409192. ( L-48 ) I am not a spring chicken and I cannot make out the smaller numbers on the block to see if it is part of the vin
tefishe
Thanks everyone.
the smaller # under the block code is CF3200 either 95 or 55 not a # matching car. That dosen`t matter, just wanted to know what I have to work with. I guess I will pull valve covers and look at casting # there
