Starter Identification
Old Apr 1, 2009 | 07:31 PM
NMT1957's Avatar
NMT1957
Default Starter Identification
This starter came off my 69 427. Anyone tell me what this really belongs to? Delco-Remy USA 1108781 5L 7 6
Old Apr 1, 2009 | 10:04 PM
ksbunting's Avatar
ksbunting
My books for GM starters only go to 1971 and I could not find this number in there which makes me think it is newer than 1971.
I was also told in the past that GM used the 1108 series for heavier duty applications than for instance the ones that start with 1107.
Corvette starters were frequently 1108 series, for instance my original starter for my 68 Corvette is 1108361.
Sorry I can't be more helpful
Kurt
Old Apr 2, 2009 | 05:45 PM
NMT1957's Avatar
NMT1957
Well if this is a heavy duty starter it might be worth getting rebuilt and restored. It wont be "correct" but Id rather have a good heavy duty one.
Old Apr 2, 2009 | 06:24 PM
nutsy's Avatar
nutsy
my 72 BB has original starter but its # 1108429.
Old Apr 2, 2009 | 08:51 PM
ksbunting's Avatar
ksbunting
I just did a Google search and came up with 1975 & 1976 Chevrolet C & K series pickup trucks as a listing for 1108781
Kurt
Old Apr 3, 2009 | 12:19 PM
Ironcross's Avatar
Ironcross
Default Builders dont go by the Numbers
The problem begins when a rebuilder replaces the parts. They are not number conscious and any front {nose} or rear plates/frames can be matched to any number case. The case is the only place the numbers appear, not the end frames. And the end frames determine what engine it will fit. ...which could be any GM car or truck..
Old Apr 3, 2009 | 12:25 PM
Derrick Reynolds's Avatar
Derrick Reynolds
St. Jude Donor '13-'15, '17 thru '22
The starter on my car has numbers on the casing that point to a late '70s Pontiac. The thing about that is all Pontiacs from that era had the starter on the driver's side, so the case obviously no longer has it's "born with" nose.
If you are trying to sell it, I believe all you really need to know is that it is a "10MT" starter for a passenger side starter location. Other than that, I believe they are all the same. However, I don't claim to be an expert here.
Old Apr 3, 2009 | 12:32 PM
Ironcross's Avatar
Ironcross
Pontiac and Olds engines use the same end frames and likewise the Chevy, Buick, Caddies, of some years are the same switching sides for the V8 engines of these cars.
Old Apr 3, 2009 | 12:46 PM
Ironcross's Avatar
Ironcross
Kurt
Both of these starters use the same end frames and noses regardless of its numbers on the cases and will fit several different years higher or lower the model year. Besides case numbers being different there is the location of the field post to the switch that determines either a high torque or standard starter. Large cubic inch engines received the high torque and the smaller received the standard for most OE applications.
Old Apr 3, 2009 | 02:55 PM
papawana's Avatar
papawana
Default starter
my book shows there were two bb starters for 1969
1108400 non m22
1108351 with m22
Old Apr 3, 2009 | 06:45 PM
Ironcross's Avatar
Ironcross
1108400 non m22
1108351 with m22
What that could mean is that there are two different noses that fits 427`s but i recall there actually wasn`t,. Or a high torque starter number for the solid lifter high performance engines and a standard for the hydraulic cammed engines with a different OE number that sounds more reasonable. Now the 1970 454`s used again a different nose. But all the cases were interchangeable....
Old Apr 3, 2009 | 07:15 PM
hurry88's Avatar
hurry88
Looks like a 1975 November 7th day. My GM parts manual 1953 to 1973 does not show that number. ???
Old Apr 3, 2009 | 07:24 PM
Ironcross's Avatar
Ironcross
for a 69 it should have a cast iron nose,
To Starter Identification
