Vented battery?
Old Apr 5, 2009 | 05:31 PM
ron69's Avatar
ron69
Default Vented battery?
Just went to NAPA to get a new battery. The counter person found the application in the computer and I was ready to buy it and another counterman said I couldn't use a regular battery in the Vette. He told me it needed to be a vented battery since it sits in the passenger area. I decided to wait to see what the knowledgeable people on this forum had to say. I've been helped many times and learned a lot in the 5 years I've owned my '69 small block.
Thanks, Ron
Old Apr 5, 2009 | 06:02 PM
Gordonm's Avatar
Gordonm
Nah! You beleive the Napa guy? Most batteries now are sealed batteries and do not need any venting. The old style batteries that had the caps were vented and had the hoses run out the bottom of the battery box. I have never had a Vented battery in my car. Always been a sealed type. I just run a standard Die Hard in mine.
Old Apr 5, 2009 | 06:06 PM
ron69's Avatar
ron69
Thanks, I thought he might be wrong, but this is my first Vette and I heard some of the rules that apply to other cars don't apply to Corvettes.
Thanks again, Ron
Old Apr 5, 2009 | 06:12 PM
Ganey's Avatar
Ganey
Ron
I have seen a source show low gassing batteries for C3. Later C3 came w/ maintenance free sealed batteries. Some "maintenance free" are not sealed.
CU liked the larger Napa Select 84 for north "maintenance free".
Some of us use Optima normally Red (sealed).
Old Apr 5, 2009 | 07:04 PM
BKarol's Avatar
BKarol
There are some cars ie. 2002 Buick Lesabre where the battery is under the back seat and yes they need venting just in case there are fumes being emitted. He is comparing this set up to yours.
Your vette probably has a hole in the battery compartment that works just fine. Enough ventilation.
Old Apr 5, 2009 | 07:11 PM
wer2xu's Avatar
wer2xu
get an optima...little more expensive...but worth it.
Old Apr 5, 2009 | 07:23 PM
ron69's Avatar
ron69
Thanks for all the replies. I'm going to look into the Optima also.
Old Apr 5, 2009 | 07:26 PM
Ganey's Avatar
Ganey
AutoZone has Optima.
To Vented battery?
