350 sb Brass Fitting - Question
Old Apr 5, 2009 | 11:37 PM
70Yellowbird's Avatar
70Yellowbird
Default 350 sb Brass Fitting - Question
What is the little threaded brass fitting called that is located on top of the engine block just to the left of the distributor? A very small black tubing is connected to it.
Also, where can I buy it?
Thanks.
Old Apr 5, 2009 | 11:51 PM
DZRick's Avatar
DZRick
That would be your oil pressure line.
You might be able to get one at NAPA
Old Apr 6, 2009 | 07:17 AM
Gordonm's Avatar
Gordonm
There are compression fittings in there also.
Old Apr 6, 2009 | 07:49 AM
Glassbowtie77's Avatar
Glassbowtie77
Old Apr 6, 2009 | 08:04 AM
JimT's Avatar
JimT
Check Home Depot, look in their brass fitting plumbing department. They have fittings, ferrules and tubes.
To 350 sb Brass Fitting - Question
