Replacing Speedo Cable
Old Apr 7, 2009 | 03:00 PM
MikeIz 82VETTE's Avatar
MikeIz 82VETTE
Default Replacing Speedo Cable
hey guys,
speedometer not working, my question is which would be more likely to break the top or bottom? and how much a pain to get too? lol
thanks!
Old Apr 7, 2009 | 03:52 PM
Wuttin's Avatar
Wuttin
Originally Posted by MikeIz 82VETTE
hey guys,
thanks!
Could be tricky...do you have cruise control? On my 79 the little orange plastic nose that inserts into the fitting had sheared off at the cruise transducer...real easy to get to and a good first place to look if you have cruise. In the end if it's just the cable it's an easy fix. If it's in the speedo head it's a little more challenging.
Old Apr 7, 2009 | 03:55 PM
MikeIz 82VETTE
cool, i'll start there. so i get to it from the cruise control right? thanks!
hopefully the speedo is good!
Old Apr 7, 2009 | 04:19 PM
Ganey's Avatar
Ganey
The lower one & easy. You can disconnect the upper one at cruise transducer & spin cable to speedo to check. Most likely the issue is the transducer not turning easily.
Old Apr 7, 2009 | 09:32 PM
C3 4ME's Avatar
C3 4ME
I'd chuck up first the lower one in a drill and see if it spins the speedo. If so, then I'd disconnect the upper one and chuck it up and see if it still spins it. I think you have to run the drill in reverse.
Old Apr 8, 2009 | 11:31 AM
MN-Brent's Avatar
MN-Brent
Pretty good chance your cables are fine and your problem is the cruise control transducer housing, up near the firewall. The gears inside this are nylon and they breakdown on you.
I got a replacement from Mid America ($99) and it works great. I did replace the lower speedo cable while I was at it, but probably did not need to.
Speedo is silky smooth now.
Brent.
Old Apr 8, 2009 | 12:29 PM
red topless gator's Avatar
red topless gator
Brent.
, However you can buy this transducer at almost any auto parts store for about half the price.................LT
To Replacing Speedo Cable
