Door hinge spring replacement procedure?
Old Apr 8, 2009 | 12:45 PM
MakoShark72's Avatar
MakoShark72
Default Door hinge spring replacement procedure?
Search function no help. Is the procedure posted somewhere? I know about the bent screwdriver tool, but not sure the correct side to pry up, rotate, etc. Then the reinstall procedure?
Thanks.
Old Apr 8, 2009 | 01:33 PM
427basketcase's Avatar
427basketcase
Clickey here:
http://www.ecklers.com/assets/pdf/40931.pdf?
Old Apr 9, 2009 | 12:45 AM
vett us all's Avatar
vett us all
Thanks.
I installed mine with a regular cheap screwdriver I bent myself.
Old Apr 9, 2009 | 09:23 AM
Ken74Conv's Avatar
Ken74Conv
Am I right that the screw driver in bent to 90 deg.
Thanks,
Old Apr 9, 2009 | 10:09 AM
70Yellowbird's Avatar
70Yellowbird
That's what worked for me w/ no problems.
Not true ... it's probably closer to a 45 degree angle ... here's a pic from a vendor website:
Old Apr 9, 2009 | 02:08 PM
Ken74Conv's Avatar
Ken74Conv
OK, That's great. Thanks
To Door hinge spring replacement procedure?
