Tips For Cleaning Sidepipes
Old Apr 8, 2009 | 10:59 PM
addballer696's Avatar
addballer696
Default Tips For Cleaning Sidepipes
There seems to be a lot of tar on the headers near the wheel that is extremely hard to get off because it gets caked on from the heat. Any tips out there to help get this off?
Old Apr 9, 2009 | 12:23 AM
vett us all's Avatar
vett us all
Try PB blaster, or mineral spirts. Let it soak a few minutes, and wipe it clean with an SOS pad and water.
Old Apr 9, 2009 | 08:11 AM
samh's Avatar
samh
I haven't tried it on tar, but from stubborn and caked in brake dust to crayon masterpieces on bedroom walls, WD-40 works great! Worth a try.
Old Apr 9, 2009 | 08:37 AM
78VetteChic's Avatar
78VetteChic
Try "De-Solv-It" for removing road tar. I've been using it for over 10 years for removing all types of gooey stuff, including tar on car paint and never had a problem. It's water rinseable, too. I squirt some on a rag wrapped around my finger and use light pressure circular motion to remove tar spots without scratching and then follow it up with a soapy wash afterward.
I never tired it on chrome but it should be OK - try small test spot first.
Here's the company who distributes it. You can find it in hardware stores (Ace, Handi Man) or online (Amazon) -
http://www.orange-sol.com/household/index.html
Good luck!
Old Apr 9, 2009 | 10:31 AM
CCrane65's Avatar
CCrane65
Send them to me...I'll take care of them!
Old Apr 9, 2009 | 11:06 AM
guitarcrazy02's Avatar
guitarcrazy02
I thought about this technique too, but I'm worried about leaving a million little scratches in them. You think it would be ok on stainless?
Old Apr 9, 2009 | 02:35 PM
addballer696
I'll give the WD-40 a try since i have that already laying around at home.
Old Apr 9, 2009 | 03:24 PM
LIQUIDDRAGON's Avatar
LIQUIDDRAGON
we cant give you any real good tip on cleaning the pipes if you dont tell us what they are made of.
Old Apr 9, 2009 | 04:34 PM
78VetteChic
A good scrubber that doesn't scratch, try a "Dobie" pad, (in grocery stores, Walgrees, etc). Dobie pads are a plastic mess with a sponge inside. I use them on my pots and pans, and counter top as to avoid scratching. Here's the Walgreens description if you're interested -
  • 4.3 in x 2.6 in x 0.5 in.
  • Scour without scratching.
  • The original.
  • Dobie Pads Clean It All:
    • Kitchen: All Teflon and Silverstone coated cookware, dishes and china, counter tops, aluminum and cast iron, enamel and porcelain, appliances, fruits and vegetables.
    • Bathroom: Tile, shower door and fixtures.
    • Household: Walls and spot cleans carpets.
    • Clothing: Spot cleans clothing, suede shoes and hats.
    • Automobiles: Cleans chrome and can be used to prepare tires and whitewalls for detailing. Removes insects from bumpers, grills and windows.
    • Hands: Cleans grimy and greasy hands. Ideal for manicures and pedicures.
  • Made in Mexico.
Old Apr 9, 2009 | 05:39 PM
Older Than Dirt's Avatar
Older Than Dirt
When I had chrome sidepipes I used 0000 steel wool on the headers.
Old Apr 9, 2009 | 06:15 PM
redman76's Avatar
redman76
St. Jude Donor '09
I'd be more concerned using SOS on stainless. I just cleaned my SS pipes to remove all the baked-on oil stains (I'll never tell how those got on them ) and I used Mother's metal polish and a cloth. They cleaned up pretty quick and easy.
Old Apr 9, 2009 | 06:55 PM
smon's Avatar
smon
what are you guys using for jet hot silver finish. I have some tar and some light scratches on the tubes. Are any of those mothers metal polishes ok to use?
Sean
Old Apr 10, 2009 | 01:33 AM
vett us all
Yes. The scratches would be so shallow, they will rub out with any SS polish. Test a small spot and see for yourself.
Old Apr 10, 2009 | 01:39 AM
vett us all
Sean
I had oil stains on my Jet Hot coated pipes, and could not get them clean. I tried every thing. Not sure about the tar stains. My guess would be, the tar will not come off all the way since tar is oil.
Old Apr 10, 2009 | 02:47 AM
Bangkok Dean's Avatar
Bangkok Dean
A tip I can offer for Chrome and stainless steel pipes is use never dull wading with semi chrome paste polish. The never dull is a little abrasive and the semi chrome gives a bright luster and the two together won't scratch the finish, even when the stainless gets that gold look they come back to a chrome like finish easily.
I have never used this on jet hot but I think it is worth a try.
Old Apr 10, 2009 | 09:59 AM
corvetteload's Avatar
corvetteload
gasoline works great to remove tar
Old Apr 10, 2009 | 11:37 AM
smon's Avatar
smon
I used that never dull wading and it seems to work pretty well to get the tar and stains off my jet hot pipes. Now for those little scratches that I have on there, Ill try a couple different ones to see how it works out. But should I just use a microfibre cloth and lightly go in circles or can I use something like that Mothers Mini Powerball?
Old Apr 10, 2009 | 01:03 PM
dannyman's Avatar
dannyman
Use the least aggressive approaches and work your way up.
I would start the car to slightly warm up the pipes, shut-down and when warm to the touch apply hand cleaner, yes, good old fashioned mechanics hand cleaner and allow it to soften the tar. Rinse well. Repeat as necessary.
You need to exhaust all type of non-corrosive cleaners to remove the tar before going to the extent of scraping the pipes.
To Tips For Cleaning Sidepipes
