Tip - Remove grease from interior carpet!
Old Apr 11, 2009 | 10:59 PM
78VetteChic's Avatar
78VetteChic
Default Tip - Remove grease from interior carpet!
If you ever get grease on your interior carpet here's a tip for you.
Today while putting the seats back in after working on the dash and other stuff from this week I noticed a spot of grease got on my OYSTER WHITE carpet. No problem - I grabbed the bottle of "De-solv-it" from under the kitchen sink, squirted a very small amount on the carpet just enough to cover the diameter of the spot (don't over soak the spot, just get the fibers wet) and then absorbed the grease spot with a blue (paper) shop towel and with a small amount of light circular wiping. It took about 3 applications to remove the spot. I continued to use a clean side of the shop towel each time. The grease spot is completely gone and no stain! Sorry I didn't take any before and after pics to share with you guys - it was a busy day in the garage today while the weather was nice.
De-solv-it has a strong citrus smell to it so if you use a lot of this stuff to clean up a number of grease spots then leave the windows open for a day or two as to air the car out.
Old Apr 12, 2009 | 07:53 AM
stevekk's Avatar
stevekk
Thanks. Good tip. Never heard of that stuff, but will look for when I shop. Where did you buy it?
Old Apr 12, 2009 | 01:43 PM
78VetteChic
I've had my bottle for about 10 years. It even gets chewing gum out of carpet - amazing stuff.
Here's a list of retailers.
http://www.orange-sol.com/household/moreretailers.html
Amazon.com carries it too if you can't find it locally.
To Tip - Remove grease from interior carpet!
