What a Bad DAY
Old Apr 16, 2009 | 09:32 PM
gregsvette1979's Avatar
gregsvette1979
Default What a Bad DAY
SO I finally pulled out the corvette from storage today.. Brought it into my garage and replaced the radiator as it was leaking. Which wasnt as bad as I thought it was going to be..
anyways I had a neighbor come over to help me put the hood back on and he asked me if the car was always racing and never idling correctly. I told him yes and he pulled off a hose and then pluged the nipple on the carberator. When he did that the engine calmed right down and idled I thought it was going to be a great thing.... then I heard it.. YUP and knocking in the lower part of the engine.. I think a rod got screwed up or something...
NOW I NEED TO REPLACE THE ENGINE.. I was all excited about driving the car tomorow to work.. that isnt happening now.. DAMMMMMM
Just had to vent..
Old Apr 16, 2009 | 09:38 PM
chris75stingray's Avatar
chris75stingray
if it's only a rod bearing that's easy to change. no need to pull the engine
Old Apr 16, 2009 | 09:40 PM
gregsvette1979
how would i know. all i know is that the noise is in the bottom end of the engine..??
Old Apr 16, 2009 | 11:33 PM
earthquake68's Avatar
earthquake68
Pull the pan and try to move the rods one by one against the crank. You can feel a loose one even if it only has .005-.010 extra play. With oil on the crank, they shouldn't move at all side to side. They Will slide a little back and forth on the crank. Let it run a little bit. If the knock goes away after it warms up, it could be a wrist pin. If it does go away when it's warm, drive it. They can go like that for years. If it's a rod or main bearing, fix it right now!
Good luck, keep us posted.
Old Apr 17, 2009 | 06:22 AM
Jim Martley2's Avatar
Jim Martley2
I have also heard a knocking sound simular to a rod knock that was caused by a bad fuel pump. The pump produced sufficent pressure & volume for the car to run perfect but there was a broken spring inside it that caused the lever to slap the fuel pump push rod and made a sound VERY simular to a rod knock. It might be worth an hour of your time & $30 bucks or so for a new pump to eliminate it as a possiabulaty.
Jim
Old Apr 17, 2009 | 06:47 AM
Phil Zell's Avatar
Phil Zell
You could have knocked off a piece of carbon on one of the pistons and that is what you are hearing. If a piece of carbon is forced loose at start up and wedges sideways it will sound like a rod knocking. Only cure is to run it out the valve and you will be good to go.
Just my $ .02 worth
Old Apr 17, 2009 | 07:52 AM
bojangies46's Avatar
bojangies46
Do you have good oil presure?
Old Apr 17, 2009 | 10:18 AM
mdj21's Avatar
mdj21
you can also test for a bad bearing by tapping on the rod caps with a metal rod. good ones sound fairly solid while bad ones will sound hollow.
good luck and i hope it's not a rod bearing. i wasn't so lucky...
Old Apr 17, 2009 | 04:45 PM
SEVNT6's Avatar
SEVNT6
Just my $ .02 worth
I saw this happen once at my Uncle's shop years ago. I guy came in with a '78 or '79 Malibu that was hammerin'. He thought it was new motor time. My Uncle ran some ATF down the carb while running the motor around 2 grand, and old trick from way back. The carbon broke loose & the knock went away. And my Uncle had a new customer for life...........
Old Apr 18, 2009 | 04:04 PM
gregsvette1979
I brought it to a shop around here and he said that he doesnt think that it is a rod.. He also doesnt think that its the fuel pump.. He however has no clue what it is though.. Im just gonna drive it.. if it goes ill replace the motor with a 383 stroker that i know of for sale..
Hope everyone has a great weekend..
Greg
Old Apr 19, 2009 | 10:55 AM
71coupe454's Avatar
71coupe454
I had an automatic GTO that had loose fly wheel bolts and knocked at a low idle, half a turn on the bolts fixed it..
Old Apr 19, 2009 | 11:33 AM
jbowles49's Avatar
jbowles49
You can pull spark plug wires one by one. If the knock gets louder it's that cylinder. Good luck
To What a Bad DAY
