Want Smoother Ride
Old Apr 19, 2009 | 05:45 AM
baron22's Avatar
baron22
7th Gear
Default Want Smoother Ride
I will be replacing tires (15") and shocks on an 82 and my main concern is obtaining as smooth of ride as possible. What combination of tires and shocks would you recommend?
Old Apr 19, 2009 | 07:40 AM
wer2xu's Avatar
wer2xu
A 1977 Cadillac Fleetwood...
There are not that many tires out there for your car that are going to change the ride a whole lot...stick with Bridgestone or Goodyear...as far as shocks go save your money and buy AC Delco shocks...keep in mind this is a sports cars, not a luxury car so the ride is never going to be "smooth".
Old Apr 19, 2009 | 08:05 AM
Glassbowtie77's Avatar
Glassbowtie77
If your car has stock suspension on it than I would go with AC Delco shocks and a set of Firestone Firehawk Indy 500's. They are every quiet riding and have as comfortable of a ride as a Corvette can have. I have these tires on mine and I'm extremely happy with them. Keep in mind that your Corvette is a sports car, not a luxury car and doesn't have luxury car suspension, so don't expect it to ride like one.
Old Apr 19, 2009 | 08:37 AM
noonie's Avatar
noonie
Lower your tire pressure to the max allowable for even tread wear. Makes a huge difference. It's an old car dealer trick.
Any cheap base shocks and wide 60 series tires will help a lot too.
Old Apr 19, 2009 | 10:25 AM
71coupe454's Avatar
71coupe454
I use monroe sensatracs a lot, they have valving in them that make them softer on smooth road surface and they stiffen up when needed on rough surface. The tire pressure on the tire sidewall is the MAX pressure! You can come down with that for smoother less firm ride. and of course I have to say "Fly with Eagles!"
http://www.monroe.com/products/sensatrac_passenger.asp
To Want Smoother Ride
