1982 corvette help
driving,i have installed a new ecm,prom,distributor,fuel pump and plenium gasket.the tach is erratic and the check engine light flashes erratic as well when i plug my scanner in i have no trouble codes. Help please !!!!!!!!!!!!
Hope that helps!
http://crossfireinjection.net/index.html
WinALDL is software that me help you locate an erratic sensor as well. Its free and you only need to build up a cable to talk with your PC. You can find it on Joby's site. Just google WinALDL.
Mine was starting to surge at idle, along with periodic high idles up to 1500 when cold. After I replaced my manifold for a ported model
and all the gaskets that go along with it, my high idle-surging problem went away. I did not touch the TBs.I'm also not running any vacuum to anything other than the headlights. Check your brake booster for a leak.
Have fun.
