one wire alternators
Enjoy. I could answer but I don't want to give you bad info. You should head over to the C3 General Forum and ask the guys that will know for sure. Good luck.
http://forums.corvetteforum.com/c3-general-119/
Welcome to the Forum...
A 1-wire alternator works best for low amp draw constant applications like machinery and tractors. The further away from the battery you get, the worse it performs. Stick with the stock style 3-wire or get a CS144 (stay away from CS130). There are plenty of articles and posts on this upgrade.
They only reason to add a 1 wire Alternator is easy install.
your electrical system will function much better with the corrct alternator that uses voltage feedback.
