rattle can undercoating ?
Old Apr 29, 2009 | 10:33 AM
nd4speed's Avatar
nd4speed
Default rattle can undercoating ?
has anyone used it? did it turn out alright?
Old Apr 29, 2009 | 10:47 AM
tracdogg2's Avatar
tracdogg2
Yes, if you use the right stuff. The best I have found is sold at Napa. Dark green can with a black top and an extra red nozzel. Says "Nascar" on it..
Mike
Old Apr 29, 2009 | 11:33 AM
Quil's Avatar
Quil
I used some on the fenderwells of a Bronco I used to have...worked and held up surprisingly well.
Old Apr 29, 2009 | 11:42 AM
The Money Pit's Avatar
The Money Pit
I did a car years back with canned undercoating, and though it came out OK, felt a pro job would have been better,and maybe even cheaper. The canned stuff I used was fairly thick, and under high pressure, so when you pressed the nozzle, the can would empty in seconds. Took me a case of cans to do the whole job.................And then the cleanup after...........OMG!!!!
If I were to do it again, it'd be cheaper to pay the pro's.
Old Apr 29, 2009 | 01:55 PM
Kevins77's Avatar
Kevins77
My buddy used the spray on bedliner stuff as an undercoating and on his engine bay of his car.. looks VERY good still after a couple of years. I would recommend that to anyone after seeing the job he did.
Old Apr 29, 2009 | 02:02 PM
nd4speed's Avatar
nd4speed
thanks guys, i'll buy a can of ea. and see which i like
Old Apr 29, 2009 | 02:06 PM
Grumpy 427's Avatar
Grumpy 427
There is a Product here in Canada called EZ-liner. I have seen it used and it has a smooth finish.
Old Apr 29, 2009 | 07:38 PM
Solid LT1's Avatar
Solid LT1
I used 3M "professional" undercoating from Wal Mart on my 70 LT-1 after spending $18K for a new paint job. Like the old saying oes: "a can a day keeps the star chips away" in other words, I used a full can in each wheel housing to coat the feneder where a stone impact will cause a paint failure that I know as "star chipping". One word of advice, wear a hat/respirator while doing the job and do it in a well ventalated area (don't ask about the hat recommendation just take my word on this piece of advice!)
Old Apr 29, 2009 | 09:22 PM
tnovot's Avatar
tnovot
Many years ago, I used the spray can stuff on the wheel wells of a '68 Camaro and was very happy with it. Don't remember the brand name but I think it came from K-Mart.
A few years ago, I detailed my C4 with a water based undercoating I got from J. C. Whitney. It came in a gallon can and I applied it with a sponge. Put on 2 coats and it was probably still thinner than what a spray can would give but I wanted appearance more than protection. It was a little tedious to apply but it could apply it exactly where I wanted and there was absolutely no cleanup of other underbody or suspension parts. Also, no respirator or noxious fumes which was important since I did it in a closed garage during cold weather with a gas heater running.
Terry
Old Apr 29, 2009 | 11:59 PM
nd4speed's Avatar
nd4speed
thanks again fellas. seems like a good way to go
Old Apr 30, 2009 | 12:46 AM
hwcoop's Avatar
hwcoop
I used black rubberized rockgaurd ..has a slight texture and is resistant to chips. Easy to touch up if required and is washable. Dirt & dust will stick to regular undercoating
Old May 1, 2009 | 11:19 AM
2K-C5's Avatar
2K-C5
hwcoop: What was the Brand/Item# of the black rubberized rockgaurd you used?
It looks good and should stay better looking with a little clean up now and then.
To rattle can undercoating ?
