She lives again....
Old May 1, 2009 | 03:53 PM
Budman68's Avatar
Budman68
Cruise-In VII Veteran
St. Jude Donor '07
Default She lives again....
Fired up on the first try, but had a few fuel leaks. Actually a lot of fuel leaks. Fixed most of those and then the oil filter started puking. Changed it, adjusted a few lose lifters. Ran for 20 min. at various idles speeds and shut her down. Did I forget to say the radiator puked also. To much air in the system. Anyway, she works and once I sorte out the fuel line problems I will take it for a ride.
Old May 1, 2009 | 06:08 PM
Budman68's Avatar
Budman68
St. Jude Donor '07
Repaired the fuel lines with rubber, until I can fix it right. Went for a spin and need to adjust first gear linkage. Still needs a lot of tuning. Timing and air/fuel is off. Can't wait to spin it to 7000.
Old May 1, 2009 | 06:20 PM
DZRick's Avatar
DZRick
You've done a lot and come a long way with your vette.
Congrats on getting it running and once you get past the leaks and final tuning have a great summer with it.
Old May 1, 2009 | 06:26 PM
Budman68's Avatar
Budman68
St. Jude Donor '07
Thanks, also I saw my back up lights work for the first time. Small things that make you smile.
To She lives again....
