fuel pump issue
Old May 3, 2009 | 10:07 AM
bracer's Avatar
bracer
Default fuel pump issue
good morning all.i have a 73 with a L-82 in it.i have put everything back together and am ready to start.problem i have is no fuel past the in line filter before the carb.i thought maybe the pump.i replaced it and still no fuel past the filter.i can see fuel in the filter.this car has a new tank and sending unit.i made sure there was enough fuel to submerge the sending unit.line were blown thru prior to installing fuel hose.so has anyone ever heard of the rod pushing the pumps arm to wear down enough to cause this kind of problem?i never have.but i am at a loss as to why i am haveing this issue.thanks for any help.
Old May 3, 2009 | 10:18 AM
Ganey's Avatar
Ganey
Prime the carb. Make sure the short hose to the fuel pump is not kinked. After that you could try clamping the return hose.
Old May 3, 2009 | 10:27 AM
Duke94's Avatar
Duke94
Are you saying that if you disconnect the hose at the carb and crank it over, nothing comes out? You might not have enough fuel in the tank and the pump is sucking air.
Gary
Old May 4, 2009 | 09:58 PM
Lon Wayne's Avatar
Lon Wayne
did you turn the engine over and check out the rod for movement i just did mine I pulled Number 1 plug out brought it up to tdc the rod was all the way up then I turned it 180 diff it came down . I then fought the dirty bast@#@ well you know .I still have a one drop per month leak welll two beers.How much gas is in the tank????
Old May 4, 2009 | 10:42 PM
Skip Burney's Avatar
Skip Burney
check the short hose at the pump it is most likely kinked, it is supposed to be a molded hose
To fuel pump issue
