Looking for some wiring help/advice
Old May 3, 2009 | 07:26 PM
kortensi's Avatar
kortensi
Default Looking for some wiring help/advice
Hey Guys,
I have started to work on cleaning up the wiring harness. Here is the 1st of what I am sure are many questions.
I unraveled the covering and found the following:
I am going to upgrade the wiring from the starter to the alternator since I upgrade the SI stock alt to a CS144 alt.
Is there any problem with the plan below?
Old May 3, 2009 | 09:17 PM
c69vete's Avatar
c69vete
Finalist 2021 C3 of the Year - Modified
2017 C3 of Year Finalist
Cruise-In VIII Veteran
St. Jude Donor '07
I think some of those splices are the in line fused links and you do not want to be with out some kind of overload protection.
Old May 3, 2009 | 09:40 PM
CheezMoe's Avatar
CheezMoe
St. Jude Donor '11-'12-'13,'19-'20
Looking at your top drawing, counting the the slice points l-r as 1-4, the segment between point one and point two would be a fusible link. The segment off splice 3 feeding the fusebox is another fusible link.
I just rewired all this on mine but keeping stock alternator for now so keep factory config.
MadElectrical has all parts and instructions for what you wish to do.
www.madelectrical.com
To Looking for some wiring help/advice
