Speakers are on a plug, The original car radio also had an FM modulator up under the passenger side dash (you don't need that any more). You will have to pull wires to determine where they go.
Should have a permanent hot wire,
A switched hot wire,
A power antenna wire,
Dash light wire.
well i decided for the mean time, im gonna put a aftermarket in.
what radio are you guys using? what speakers? will i even be able to hear the radio with just 2 in the dash?
