Headlight problems
Old May 4, 2009 | 10:46 PM
Stinger 77's Avatar
Stinger 77
Default Headlight problems
Hey guys. i just got my headlights to go down using the manual override switch, but they will not go up or down when i use the headlight switch. The lights themselves come on, but the headlight assembly will not go up or down.Could the headlight switch possibly not be holing a vacuum. any help is much appreciated. thanks.
Old May 5, 2009 | 04:42 AM
DMONSVETTE's Avatar
DMONSVETTE
You can push your lights up from under the car if need be.
In the meantime, the link below will probably cure your problem.
http://www.corvettemagazine.com/2002...s/lights-1.asp
Also, have you tried using the search feature here?
Your questions is probably the #1 or #2 question asked on the forum.
HTH
Old May 5, 2009 | 06:47 AM
Ganey's Avatar
Ganey
http://www.corvette-101.com/
Check hoses to headlight switch.
To Headlight problems
