broken tail light bolt fix ?
Old May 5, 2009 | 11:23 AM
nd4speed's Avatar
nd4speed
Default broken tail light bolt fix ?
for those of u that have broken them off. what did you do to fix them?
Old May 5, 2009 | 12:09 PM
Lon Wayne's Avatar
Lon Wayne
You might be able to take it all the way out from the back with a wire cutter is any of it sticking out take the lens out and see if you can get any threads to get ahold of To counter screw iot out????
Old May 5, 2009 | 01:21 PM
eastltd's Avatar
eastltd
I have two light assemblies to fix with the same problem.
My plan is to drill out the remnants of the broken studs and tack in new carriage bolts.
I'm also open to suggestions.
Old May 5, 2009 | 01:59 PM
Duke94's Avatar
Duke94
I drilled out the broken one and used a nut and bolt.
Gary
Old May 5, 2009 | 02:05 PM
nd4speed's Avatar
nd4speed
nut and bolt is what i was thinking.
Old May 5, 2009 | 02:18 PM
427basketcase's Avatar
427basketcase
I purchased these from Zips.
Linky:
http://www.zip-corvette.com/Zip/prod...C9CDF6926FAC7B
Old May 5, 2009 | 02:23 PM
pbcanney's Avatar
pbcanney
Old May 5, 2009 | 02:45 PM
Duke94's Avatar
Duke94
Originally Posted by pbcanney
Now you're talkin!
Old May 6, 2009 | 11:46 AM
jaki30's Avatar
jaki30
Default Riv nut
Drilled out the broken studs and put in a Riv-Nut, then used a 1/4"-20 bolt with a low head. Worked great. Oh, also used an external tooth lock washer to ensure I had a good electrical ground.
To broken tail light bolt fix ?
