Hood clearance question
Old May 6, 2009 | 07:44 PM
cnauta70's Avatar
cnauta70
7th Gear
Default Hood clearance question
I have a stock base 350 cu. inch corvette motor in my 1972 Corvette with of course the base hood for that year. I am looking at installing the the Edelbrock Performer-RPM or the Edelbrock Air-Gap intake manifold to this engine along with a new Holley 670 4 bbl Carburetor. I know that I won't have enough clearance with my 3 inch Air Cleaner and that base hood, but will I have enough clearance with a low profile K & N air cleaner? I looked on their website and K & N have a 3 inch Air Cleaner kit that fits snuggly over and around the Holley Carburetor making it effectively a 2 inch Air Cleaner, thereby giving me 1 inch of extra clearance for the hood, will this be enough? Or has anyone successfully performed what I am asking on their base 350 Corvette (1968 to 1973)..if so, what was your trick to get the clearance?
Thanks kindly
Old May 7, 2009 | 12:45 AM
vetteguy75's Avatar
vetteguy75
LA Events Coordinator
The best way to check your clearance is to get some plumber's putty, roll three of them in about 2" ball each and place them on the air cleaner...front, middle and rear. Gently close the hood (don't drop it...set it down, then push to close). Open the hood and the ***** of putty should be somewhat compressed....the height of the putty ***** is the clearance of the hood. You can repeat the procedure at different location on the air cleaner.
I have a 3" Fram Air Hog with a K&N drop base and flat lid. I have about 3/4" clearance on my stock hood and have been for the past 8 years....no issues or problems. I also don't drop my hood to close...I set it down completely then push one side then go to the other side and push the hood down.Good Luck!
Old May 7, 2009 | 02:28 PM
68/70Vette's Avatar
68/70Vette
Thanks kindly
Sorry not to be able to help, but this question stirred up an annoying memory.
I once called Edelbrock's tech aid phone lline and asked if their 383 crate engine (a very pricey but high quality engine) would fit in my 68 with a stock hood or perhaps a BB hood. To make the story short they were not at all interested in providing any advice. Since they sell this stuff (the crate engine, the manifolds) and Corvette owners are certainly a significant percentage of the customers who buy this stuff, you'd think they could answer the questions. Why does every individual Corvette owner who buys a manifold have to make a cold start trying to find if it'll fit. This is something Edelbrock should do.
Anyhow, I had over $10,000 setting in the bank for my 68 restore project and I would have bought their engine in a flash if they would have told me it'd fit. From what I know now, I'm sure it would. Why didn't they know that. Too bad. Oh...the $10,000 was gone after about a year and had to be supplemented.
Old May 7, 2009 | 04:56 PM
Ganey's Avatar
Ganey
LT-1/BB hood is minimum for hi rise intakes like RPM.
There needs to be at least about 3/4" clearance over the Holley vent tubes.
SEE http://forums.corvetteforum.com/c3-t...er-intake.html
Old Apr 15, 2022 | 11:06 PM
mickatbp's Avatar
mickatbp
Sorry, put my reply up before a few replies (with pictures etc) .... sorry, didn't scroll all the way to the btm of the thread.
To Hood clearance question
