A/C Issues
Old May 10, 2009 | 03:10 PM
michalbugno2006's Avatar
michalbugno2006
Default A/C Issues
I am trying to diagnose my A/C in a '79. Is there a guide for this? The air blows but the compressor never starts. Heat works fine. Could it be just the compressor? I have read something about jump starting the compressor, any ideas? Also if I want to convert to 134 (is it difficult?) would it be better to buy a certain type of compressor?
Thanks,
Michal
Old May 10, 2009 | 03:33 PM
Duke94's Avatar
Duke94
You probably lost the freon charge due to a leak. There is a low pressure switch in the system that disables the compressor if the pressure is to low. The 79' GM Service manual has lots of info on trouble shooting the system.
Gary
Old May 10, 2009 | 03:34 PM
michalbugno2006
Alright thanks.
I'll order the manual tomorrow once Willcox fixes the window motor prices.
Old May 10, 2009 | 04:44 PM
08vycpe's Avatar
08vycpe
I agree with Duke. Loss of pressure trips the switch to prevent damage to the compressor and the service manual has lots of fault trees and diagnostics.
Converting to R134a is easy and many places sell conversion kits including your local auto store. The trick is to study your system before you start messing around with it.
It is under a lot of pressure.
You need a few special tools like gauges and a vacuum pump. The gauges can be purchased with a refill kit, and the vacuum pump can be rented for free from Autozone.
Legally, you need to have a licensed person or shop remove and dispose of the old R12.
The retro kits come with what you need including new R134a compatable o-rings.
Don't leave the system open or discharged for any longer than you have to. Plug hoses when you remove fasteners.
Replace critical components.
Flush the condenser and evaporator with A/C flush.
Don't forget to add PAG oil to the compressor and system.
Here is some starter reading:
http://www.corvetteforum.net/c3/zwed...c/retrofit.htm
To A/C Issues
