L-88 Hood
Old May 16, 2009 | 07:38 PM
Engage's Avatar
Engage
Default L-88 Hood
Anyone have any pics of a 80-82 with an L-88 hood?
Mine keeps getting bubbles on it and it may be cheaper to start with a new hood!
Thanks..... Barry
Old May 16, 2009 | 08:12 PM
dmeesq's Avatar
dmeesq
Its actually a 77 with an 80 front bumper, but you get the idea.
Old May 17, 2009 | 12:34 AM
dannyman's Avatar
dannyman
Let's have a look! I need pictures of this hood and bubbles.
I am in the market for a L-88 hood.
Seriously, if you need a buyer, PM me!
Thanks Dan
Old May 18, 2009 | 12:26 PM
Lon Wayne's Avatar
Lon Wayne
Do you have the Insulation ???? Other people say theres does not bubble even without the Insl. how are you getting heat out of the motor area I just installed a 3600 CFM Electric fan and I can feel the air coming out under the car ,It blows really good my old fan did not do this .It also ran hotter with the Original Fan.
Old May 18, 2009 | 09:30 PM
Engage's Avatar
Engage
No underhood insulation.
Bubbles formed second time now pretty much in the radiator area of the hood?????? Anyone have any suggestions?
Barry
Old May 18, 2009 | 10:19 PM
guitarcrazy02's Avatar
guitarcrazy02
Barry
Are the bubbles only on the passenger side? Do you have A/C? If you do, your compressor might be what's causing the bubbles. Check to see that it isn't leaking and flinging oil up onto the underside of the hood.
As for an 80-82 with an L88 hood, here's mine. BTW, I don't have any insulation, and I'm bubble free.
Old May 18, 2009 | 10:42 PM
78Vette-SA's Avatar
78Vette-SA
Old May 19, 2009 | 08:16 AM
Engage's Avatar
Engage
Most bubbles are on passenger side but they are seem to go accross the front of the hood.And they are about 8 inches ahead of the ac and belt.Ac is now discharged but I never found any oil underhood.Anyone ever win reparing this or should I replace the hood?
Nice rides guys..... love those hoods!
Thanks..... Barry
Old May 19, 2009 | 07:26 PM
dannyman's Avatar
dannyman
Bring it to a bodyshop for an evaluation! Sounds as if it has a paint bonding (actually non-bonding) issue. Has the hood been painted lately?
Can you tell if the bubbling is the clearcoat, basecoat or down to primer or the fibreglass?
If the hood has been painted recently there may have been contamination on the surface which affected the paint from bonding properly to the fibreglass! If that's the case it needs to be stripped and prepped and painted again.
Need help posting a picture?
Old May 19, 2009 | 09:07 PM
dbeall1968's Avatar
dbeall1968
Yup, contaminated glass was my first thought. Oil, or stripper that was left on too long and got into the fibers can do that. I put 6 coats of epoxy primer on my bare glass. Overkill, but it's done now.
Old May 19, 2009 | 10:04 PM
Engage's Avatar
Engage
Car painted once... then repainted on hood because of bubbling once more!Tried to get pics but car is still parked in garage did not turn out.Will post pics later this week when I get her out.
Barry
Old May 19, 2009 | 10:15 PM
dannyman's Avatar
dannyman
Barry
Be my best guess that you still have some contamination on the hood at the offensive bubbles. You need to bring it to the right shop to address the problem. The hood needs to be stripped, cleaned and properly epoxy primed then painted. You need to find a fibreglass guy to do this if your bodyshop that painted twice can't repair it correctly.
To L-88 Hood
