Gauge cluster noise question ?
Old May 19, 2009 | 01:39 PM
Prestige593's Avatar
Prestige593
Default Gauge cluster noise question ?
The gauge cluster and new dash pads are all in. New speedo and odometer reset cable also. The lights, 4 way, horn, and turn indicators all work.
The problem: While driving, I hear a clicking as if the turn indicator was activated. This clicks when the car is moving. At higher speeds (50+) the speedo needle bounces. I was told that this could be from the speedo gear behind the gauge is slipping. Does this sound right? The odometer does not work now either. Is there a simple fix? I just got the car together and don' want to take it back apart.
Old May 19, 2009 | 02:13 PM
Lon Wayne's Avatar
Lon Wayne
Do you have one of the cable greasers ? I would try that first.I have one ,great little product un-hook the line, hook it up to the greaser and pump in some light weight grease .I wire tied my speedo cable down in two places Mine jumps A little but not much at say50mph.
Old May 20, 2009 | 08:56 AM
Ganey's Avatar
Ganey
The speedo cable takes a set & moving it out of position can cause a clicking. Putting it back in previous position can fix.
Old May 20, 2009 | 11:27 PM
Prestige593
Ganey, Explain what you are talking about. What previous position are you speaking of? Thanks
Old May 21, 2009 | 08:53 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Originally Posted by Prestige593
...The odometer does not work now either....
I'm willing to bet your clicking sound is the odo. No easy way to repair it without taking the speedo out.
To Gauge cluster noise question ?
