Dash lights not working
Old May 25, 2009 | 05:02 PM
Dantana's Avatar
Dantana
Default Dash lights not working
I've been trying to track down the source of my dash lights short for some time with no luck. Today I got out the voltmeter and started running thought the connections. First, me gauges are all functioning normally. I checked the fuse block for voltage and found that with the ignition off I got constant power to one slot (BAT) as expected. However, when the ignition is turned to the AUX position I get 12V to each slot with a fuse in it except for the slot labled "INST LPS". Also, I notice that the light bulb wires are all gray and crimped together behind the radio. There is a beige wire that runs out of the crimped gray ones and runs across and then it appears to run through the firewall just above the fuse block. So far I haven't been able to find it in the engine compartment.
Anyone have a wiring diagram? Recommendation on place to buy a wiring diagram? I'm starting to think someone got creative...
Old May 25, 2009 | 05:22 PM
...Roger...'s Avatar
...Roger...
The slot labled "INST LPS" will not be hot until you turn the headlights on and rotate the ****.
The Dr.Rebuild wiring diagrams are great.
Old May 25, 2009 | 05:44 PM
john roth's Avatar
john roth
Doc Rebuild for sure, pictures for us challenged people.
I want to mention too, the only way I got my dash lights to work was to run multiple ground wires from any metal in the dash containing a bulb to the support bar under the top dash pad. I don't know which one was the cure, but I had enough.
JR
Old May 25, 2009 | 06:55 PM
Duke94's Avatar
Duke94
Here's a very good wiring diagram for a 78'. It should be close to your 74.
Gary
http://www.corvetteforum.net/c3/tune...l/index6.shtml
Old May 25, 2009 | 08:36 PM
Dantana's Avatar
Dantana
John, you are suggesting that the bulbs are not grounding themselves correctly so running those wires took care of it?
Old May 26, 2009 | 12:12 AM
john roth's Avatar
john roth
That seemed to be the problem. Grounds are a real PIA with these cars.
JR
Old May 26, 2009 | 10:22 AM
Dantana's Avatar
Dantana
Ordered a wiring diagram from DR Rebuild. I'll go through it and also run some grounds.
Old May 26, 2009 | 10:40 AM
...Roger...
Make sure the little 5 amp "INST LPS" fuse is hot with the light switch on or all the grounds in the world wont make the dash bulbs light up.
Old May 26, 2009 | 10:55 AM
Dantana's Avatar
Dantana
Fuse definitely not hot, which was my initial concern. Recommendation above is to turn the **** counterclockwise to "on" while lights are on and see if it heats up for me. I'll try that later today or tomorrow...
If that thing should be hot anytime the lights are on I definitely have a problem.
Old May 26, 2009 | 05:13 PM
CCrane65's Avatar
CCrane65
You may have a problem in the headlight switch also. I accidentally knocked my harness connector off my switch while replacing the top dash pad and the inst. lamps went away. Didn't know the harness came off until I retraced my steps from earlier.
cc
Old May 26, 2009 | 06:15 PM
Gordonm's Avatar
Gordonm
I thought I had my dash light problem solved. The ywould stay on when the car was not moved. When Istarted to move and the car got jostled around it blows the fuse. I had the console dash out and secured up all the wires and grounds. Drove it last week for about 40 minutes and the lights stayed on. I then hit a large rut in the road and they went out. I guess I did not find them all.
Old May 26, 2009 | 06:24 PM
...Roger...
I know its probably not a huge deal to you but you could always split the dash from the center cluster and run separate fuse and see which one blows...it would at least tell you which set of lights was blowing the fuse.
Old May 26, 2009 | 06:35 PM
Gordonm's Avatar
Gordonm
There is an idea.
Old May 27, 2009 | 12:41 AM
Steve COSD's Avatar
Steve COSD
It's most probably the light switch itself. What happens is when you turn the **** it will either brighten or dim the dash lights. The way this works is there is a what is called a wiper or a piece of metal that is in contact with a small coil spring. What happens is there becomes a gap between the wiper and the spring and this is what causes the fuse to blow. You mentioned this happens when you hit a bump or the car gets jostled.
Good Luck
Steve
Old May 27, 2009 | 09:27 AM
...Roger...
Good Luck
Steve
I'm not following why the feed "to" the fuse would blow it. This seems as if this gap would just turn the power off going to the fuse. I think the short would have to be on the load side of the fuse.
Old May 27, 2009 | 11:52 AM
Wuttin's Avatar
Wuttin
The coiled spring rheostat in the light switch that dims the lights can cause lots of problems...overheating, the wire can split and lose continuity, others.
I had no dash lights. When I checked the switch it had a bad rheostat (split wire from overheating). I bypassed it by moving the green feed wire to the adjacent spade. The green wire, if I recall correctly, is routed to the INST LPS junction in the fuse block. The dimming function was lost but the lights came on full when the switch was pulled.
Move the green wire to the open slot on the left to test or bypass dimmer:
I have since replaced the switch and put the green wire back in the center slot; all works perfectly.
Old May 27, 2009 | 09:23 PM
...Roger...
IMO that overheating is from a bad connection on the unused spade next to the green wire spade-the unused spade is the feed for the rheostat which itself gets its feed from the brown wire spade.
I now on brand new switches solder that bad connection actually I solder 2 places.
edit- the green wire in the pic is in the correct location
Old May 28, 2009 | 08:10 AM
Wuttin's Avatar
Wuttin
DW thanks for the catch...you're absolutley right. I corrected the post and recommend moving the green wire to the open slot on the left to bypass the rheostat.
Can you elaborate on what you are soldering? Any pictures or detailed directions? The overheating on these switches gives me the *******
Old May 28, 2009 | 09:41 AM
...Roger...
This pic is blurry but I think you can see the 2 places I soldered.
To Dash lights not working
