Headlight doors open
Old May 27, 2009 | 04:29 PM
Blu73-koz's Avatar
Blu73-koz
3rd Gear
Default Headlight doors open
Help... I manually opened the Flip up head lights after opening the vacuum releasse valves (under stearing wheel) and now I can't get them to lower. Car was not running at the time so it had no vacuume, now it does but the doors won' t close when I turn off the lights. I closed the release valves and it did'nt help.
Its a 73, by the way.
Old May 27, 2009 | 06:43 PM
wer2xu's Avatar
wer2xu
there are little elbows on the ends of the actuators, reach up there and kink the elbow, the head lights will come right down.
Old May 28, 2009 | 11:33 AM
kapla74's Avatar
kapla74
WER, that only a way to lower them manually but sure not the solution.
Did they work ok before this? I would check all the hoses are conected. Normally when they do this is due to a vacuum leak or a valve not working/not conected.
Old May 30, 2009 | 11:02 PM
Blu73-koz's Avatar
Blu73-koz
3rd Gear
I'll try the elbow trick.
And yes they worked fine befoe.
Old Jun 25, 2009 | 03:56 PM
Blu73-koz's Avatar
Blu73-koz
3rd Gear
Found loose Vacuum hose. I reconected it and she's working fine.
Thanks everyone.
BLu73-koz
To Headlight doors open
