C5 seat upgrade
Old May 27, 2009 | 08:33 PM
Fast81's Avatar
Fast81
Default C5 seat upgrade
Searched: found threads about install but not my ??
If i were to look for C5 seats what all would i need, specifically?
Old May 27, 2009 | 11:13 PM
dropTopTx's Avatar
dropTopTx
Cruise-In VIII Veteran
I just put C5 sport seats in my 68. I used the tracks from my original seats, cut the back bracket off and fabricated my own to lower the rear and maximize headroom. Put some spacers between seat and track so that I can still utilize the seat forward/back adjustment. Wired in the lumbar and bolster controls grouping all the orange wires to a positive and all the black to ground.
Then drove 14+ hours to BG for Cruise-in. Great mod for roadtrips!
Old May 28, 2009 | 12:17 AM
tigers123's Avatar
tigers123
Default see if this will help you
http://forums.corvetteforum.com/c3-t...s-in-a-c3.html
Old May 28, 2009 | 07:53 AM
Jughead's Avatar
Jughead
Senior Member since 1492
From: Just because I'm paranoid doesn't mean people aren't out to get me...
St. Jude Donor '09
search is your friend.
Old May 28, 2009 | 08:54 AM
DJCorn's Avatar
DJCorn
MORE COWBELL!!!!!!
sorry couldn't help it when i saw tigers avatar
Old May 28, 2009 | 11:31 AM
MN-Brent's Avatar
MN-Brent
Specifically any seats from any C5 will work. Power or not. Its up to your tastes. I used C5-Z06 seats as it matched my black interior and I prefer the styling of these to the other seats.
You need to remove the C5 track and install the C5 seats frame to C3 tracks, so you dont need to worry about power or not. If you were to try to keep the power adjustability, you would have your head above the roofline of the car, as the C5 tracks are VERY tall.
Good Luck and Have Fun!
Old May 28, 2009 | 11:56 AM
Jughead's Avatar
Jughead
St. Jude Donor '09
Seats?
Old May 28, 2009 | 12:19 PM
blueray72's Avatar
blueray72
Originally Posted by Paranoid
Seats?
I wanted my seats to be as low as possible so I bolted the C3 rails to the C5 frames.
I made a template of the bolt pattern on the C3 seats
Confirmed I could get the template to work on the C5 frame
Drill and tap the C5 frame
I had to notch out a section in the C5 frame for the controls on the C3 rails.
Used washers for spacers in between the new frame and old rails for clearances
(I added more washers to the front..raised up the front a little)
Old May 28, 2009 | 05:39 PM
Fast81's Avatar
Fast81
Default So to recap
any C5 seats will work (power or manual) without tracks (use C3 tracks) with a few mods (spacers).
This will be in the 82 vert (in primer) i just picked up today
Old May 28, 2009 | 08:38 PM
MN-Brent's Avatar
MN-Brent
C5-Z06 seats in an 82:
http://forums.corvetteforum.com/c3-t...z06-seats.html
To C5 seat upgrade
